I've got the telescoping stovepipe installed. At the top and bottom of the stovepipe there are slots for screws and matching holes pre-drilled to run the screws into so everything is secure. I've done that. But I noticed there are slots in the middle too but no matching holes to receive the screws. Makes sense as it is telescoping and you can't pre-drill a hole if you don't know where they will end up being needed.
So, do you drill holes for screws in the middle once you know where they should be?
