My next scheme in my woodstove at each end of the house is to figure out how to gain some air movement via natural convection.
I realize that hot air rises and cool air falls and here is my set-up, thoughts and quesitons:
1. I've got the Keystone on one end of the house, main floor.
2. The Englander will be set-up in the basement part of the new addition in the basement of it - which is at the other end of the house. The old basement will be closed via door to the new basement and pretty much not heated.
3. The new addition's main floor is on the same level as the old part of the house. There is a stairwell leading up from the basement to the main floor of the new addition and a door from old to new structure. Nothing is really open - except that the stair case opens into a foyer/hallway and is adjustant to the door that goes between the old and new.
4. There are two bedrooms in the new addition and a bath on it's main floor. I feel the heat from the basement stove will easily heat that area via radiation vertically from the stove beneath and there will be an abundance of warm air traveling up the stairs via the stair case. The blower on the Englander ought to help with this air movement.
5. What lies between is the center section of the house. A kitchen, two bedrooms and a bath. The Keystone is in a living room at the end of the old part of the house.
6. Question is - how do I set-up a natural convection to draw warm air from both ends of the house to this center section?
7. I don't want to use box fans due to noise and just being in the way. As I said, the Englander will have a blower. I've got some ceiling fans in the old bedrooms, but I feel they are old and in need of replacement - so they will stay off for this year.
8. I'm thinking about putting some fused (for fire safety) floor louvers in the farther parts of each room from the stoves on either side to allow low cool air to fall to the old basement. This air would then be returned to the new addition basement via a louver on the bottom of the door between the old and new basement to complete the air movement cycle. Part of the cool air, but somewhat warm, will heat-up the old basement - which is a storage/work shop.
What do you think?
Any advice/suggestions would be appreciated.
Thanks!
Bill
What do you think?
Thanks!
Bill
