    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. kuribo Member
    SW WI
    What are people using for temperature sensors? Any recommendations?
    #1
    Helpful Sponsor Ads!
  2. JP11 Minister of Fire
    Central Maine
    Depends on what you are using them for. Just to monitor? Get a "temperature module" on this site with the cheap sensors from the bottom of page.
    want to log data? go with the x300
    http://www.controlbyweb.com/sensor_accessories.html
  3. kuribo Member
    SW WI
    I need some sort of well or something for those, don't I?
    Thanks again for the info...
  4. JP11 Minister of Fire
    Central Maine
    Yes. I had plumber put in Ts where I needed them.. put in the well. Sensors came with a putty type stuff to coat and put in the well. You COULD strap them down to the surface and insulate over. would work fine.
    JP
  5. Coal Reaper Member
    NJ
    i will be going the x300 route, taping sensors to tank and then spray foam over. it has relays also, 3 i believe, that i will use to turn off the storage circ pump and kick on the oil boiler if/when needed (hopefully not much!).
  6. Coal Reaper Member
    NJ
  7. EffectaBoilerUser (USA) Member
    Michigan
    Azel makes a very nice digital temp gage.
    They have a single digital display that monitors 2 temps via. sensors that can connected up to 500 ft. away using t-stat wire.
    The sensors can be mounted in a temp well or can be strapped on (they have a concave surface so as to fit snugly against a pipe surface).
  8. arngnick Member
    Mansfield, PA
