A direct connect is a setup for problems down the road and a potential fire trap as creosote cleanings pile up on the block off plate around the hot flue pipe. Do a full liner for better performance, easier cleaning and greater safety.
Thanks for your advice and guidance. That led me to disregard the chimney person who told me I could use this insert by simply sliding it into the fireplace opening and using it without any connection. This morning I had the Appalachian 52 professionally installed with a full 30' liner (8" round). It's fired up and appears to be working properly. I'm fiddling a bit with the damper and the air intakes on the sides. I'm pleased to report that all I see coming out of the chimney is mostly just the wavy air and occasionally a little bit of steam/white smoke. Yay!
As for heat coming out of the insert. It's pumping out warm air pretty nicely. I have the blower on full and while it's noisy, it's not at all unmanageable.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
