The composition of pellets
ducker Posted By ducker, Jun 25, 2008 at 7:38 PM
Thread Status:
  1. ducker
    ducker
    Feeling the Heat 2.
    NULL
    Apr 22, 2008
    380
    5
    Loc:
    Leominster, MA
    Do Pellet mills ever put additives in pellets? Maybe some type of adhesive to help them keep their shape? or to help in increasing the BTU output?
    From what I've read on the pellet wiki page it sounds as if all a pellet is (typically) is just wood fiber. that's it.
    I guess I'm a little concerned about the cheaper brand of pellet I bought.
  2. BubbRubb
    BubbRubb
    New Member 2.
    NULL
    Dec 19, 2007
    265
    0
    Loc:
    Hagerstown, MD
    I've never heard of adhesive being used to hold a pellet together. Cheaper pellets often equate to more ash which equates to more frequent cleanings which equates to less free time to plow snow which equates to unhappy wife
  3. ducker
    ducker
    Feeling the Heat 2.
    NULL
    Apr 22, 2008
    380
    5
    Loc:
    Leominster, MA
    yea but in terms of any type of toxic fumes (aside from your standard CO2) with burning a cheaper pellet vs. a more expensive one.
    I'm not really that concerned, since everything I read states it's all wood; but wife + new toddler = question everything :)
  4. Eric Johnson
    Eric Johnson
    Mod Emeritus 2.
    NULL
    Nov 18, 2005
    5,875
    147
    Loc:
    Central NYS
    There's nothing in pellets but wood residue and maybe a little paper or corn. Harmless to the toddler unless he chokes on them (heaven forbid).
  5. Wet1
    Wet1
    Minister of Fire 2.
    NULL
    Apr 27, 2008
    2,529
    9
    Loc:
    USA
    Some will have a small quantity of oil (such as soybean oil) included as well, which can increase the the efficiency of the manufacturing process.
  6. mjbrown
    mjbrown
    Feeling the Heat 2.
    NULL
    Jan 15, 2008
    397
    0
    Loc:
    Hartland,Me.
    i believe(though not sure , so dont quote me) that the process for making the pellets is putting them thru a 100 ton press.with 100 ton of pressure, they should be able to hold their shape without glues or additives.from what i read on the bio-brick when i considered those, it was all very high pressure.
    mike
  7. JustWood
    JustWood
    Minister of Fire 2.
    NULL
    Aug 14, 2007
    3,596
    505
    Loc:
    Arrow Bridge,NY
    You're right. Along with the pressure is heat and natural resins which helps to bind them together.
  8. jawquin
    jawquin
    Member 2.
    NULL
    Mar 7, 2008
    53
    1
    Loc:
    Quincy, IN
    lignin
    The press compresses the wood pellets through a die, which is designed with an appropriately sized hole, usually as small as 6 mm in diameter. The extreme pressure of the press compresses the wood and causes the temperature of the wood to rise very much as well. This temperature rise causes the lignin of the wood to form a sort of natural glue which holds the pellets together as the wood cools again.
Thread Status:
