I am replacing my wood stove with a pellet stove. My wood stove pipe is horizontally and goes straight into the wall. Can the pellet stove ppe be horizontal or does it need to be vertical. Thank you
Welcome to the forum. Does your current wood stove vent into a chimney? I don't think I've ever seen a woodstove without vertical chimney... Photo might help.
As to the pellet stove, it depends on the stove. I have a Ravelli stove (Italian) that is vented horizontal. Others require at least 3 ' of vertical venting. There are other factors that need to be considered when determining venting run ... windows, doors, eaves, intakes for other appliances, etc. I would suggest that you narrow the choice of stove down to a couple and then download the install manual. They contain specifics for venting for that stove...
I suspect your old woodstove had either a rear horizontal outlet or there was rise followed by a bend on the interior stove pipe that allowed the pipe to run nearly horizontal through the wall. Once through the wall it either entered a vertical masonry chimney or a tee with a vertical pipe chimney up to above the roof.
They make transitions from 6" or 8" stove pipe to pellet vent. This installation should be shown in your owner's manual. You can maximize or minimize the amount of stove pipe size pipe by locating the transition near the pellet stove or near the wall.
Cleaning will be more difficult since your regular brush that is sized for a pellet vent will be too small for the wood pipe.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
