Thelin Parlour pellet 3000 Fan motor problem
MAXI
2
NY
Parlour pellet 3000
Fan motor speed will not vary, can hear low freq noises coming from the fan motor.
The fan will run on high clean. I have change the fan motor brushes, situation still the same as above.
maxi said:
Parlour pellet 3000
Not sure what kind of stove that is I never heard of it but
Normally it is NOT a two speed blower
I am guessing there is a Rheostat wired from the low switch to the blower
It has adjustments for High, med, and low setting. The same fan acts as cleaning blower withfan on bottom and driven fan at the top for air flow to fire box, all this from same fan motor.
Thanks for your input on this matter.
Maxi
Normally it is NOT a two speed blower.........I am guessing there is a Rheostat wired from the low switch to the blower
Rod, it's a Thelin Parlour 3000. The owners manual says to change the brushes for problems like he has, but he said he did & it didn't help.
www.thelinco.com
Hey Maxi I would call Thelin direct. Jay Thelin is great to deal with and can get you the part you need in a hurry.
Can i have an update on the problem, you have .. i am having the same problem.
Rick
