Thermostat On/Off Compat. Stoves
wingarcher Posted By wingarcher, Aug 15, 2013 at 4:54 PM
Thread Status:
  1. wingarcher
    wingarcher
    Member 2.
    NULL
    Nov 6, 2008
    32
    5
    Loc:
    NY
    First post in the *gasp* Pellet world, been burning cord wood in the house...
    Anyway- in the polebarn I am planning a major shop size increase and wish to heat it, too. Will be insulated, NOT a garage, not a gasoline storage facility, etc etc, not wondering about potential code interpretations..... I have been using a ceiling mounted propane heater in a small shop currently in there- don't like it, too noisy, cycles endlessly, etc.
    In the bigger area thought to use a pellet stove. But as the space is used on a standby arrangement, I would like a stove that will thermostat cycle to maintain a lower level of warmth and of course allowing for "turn it up" an hour or so before an afternoon in the shop.
    Can the collective hook me up with a list of "on-off" (at the least) compatible small pellet stoves? I've been searching around and have been just getting confused.
    Nat
  2. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,101
    Loc:
    madison hgts. va
    how big is the space? ceiling height as well being a shop
    there are actually quite a few (on/off) capable units out there , we build 4 of them though they are all rated to approximately 2K sq ft in a shop situation , of my models i'd lean towards the 25-PAH unit 3 bag hopper its basically a big square box no need to be "ornate" in a shop environment,
    any "big e" owners out there? does that unit have on/off? similar to our pah im thinking its slightly smaller in size though
  3. imacman
    imacman
    Guest 2.
    NULL
    I agree w/ Mike. The PAH would be great there....plenty of fuel capacity for days of un-monitored operation and doesn't have to be a "looker".
  4. wingarcher
    wingarcher
    Member 2.
    NULL
    Nov 6, 2008
    32
    5
    Loc:
    NY
    Thanks guys. Size wise, this will open into the existing shop via doorway.... so..... 14x24 and a 30x16.. 816 feet. 2x6 construction, so "R19" all the way round, including the ceiling. The downer is the concrete slab is uninsulated and even though I put down the interlocking rubber mats (like they sell at Harbor Freight, used to see similar in ice rinks...) it's still quite a heat sink in winter. Ceiling will be pretty tall, 9-10 feet. Plus windows.... and half the walls are exterior. I was thinking of a "1500" sq ft stove, but perhaps you can advise me better on how much area they really heat.
    I'd like to do maintenance heat at 50 or so, and be able to run it up to house temp (my lady is rather cold blooded, but does like doing things in the shop...) for a few hours. If I let it go cold cold all the mass in the room is down and it takes forever to get it back. The propane maintains at 45 currently in the 14x24 but it takes a long time of cycling to get the mass in the room (work benches, some tools, etc... not a room full of mills and lathes!) up to temperature. Propane is pricey (especially when you buy as little as I do) so I hate to run the maintenance temp higher.
    N
  5. Don2222
    Don2222
    Minister of Fire 2.
    NULL
    Feb 1, 2010
    7,907
    474
    Loc:
    Salem NH
    As I am a Breckwell dealer, the answer is yes, the Big E does Auto-On/Off as well as Auto-Hi/Lo. I just got a job to work on another one today. LOL
    Also I am refurbishing an Enviro MAXX, it is rated at 70BTUs with a 3 bag hopper with Auto-On/Off as well as Auto-Hi/Lo. All automated Enviros run for 20 min on low fire before turning off to prevent short cycling with any type of millivolt T-Stat. The MAXX is the largest pellet stove! A refurbished stove can save you alot of money to start with. :)
  6. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,101
    Loc:
    madison hgts. va
    slab aint gonna hurt ya too much with pellet , biggest thing is with your existing propane setup you probably start from cold daily(guessing you kill the propane in the evening to save on it i would), with a pellet unit you could run it on a low setting overnight to hold heat in the thermal mass without burning that much fuel. a 1500sq ft unit would likely get it done , i don't make one which has on/off (yet im working on it) but with "on/off" it doesn't really matter
    that with a shop environment was why i was thinking of my PAH and breckwell's "big-e" both are capable heaters , not expensive and both have big hoppers and the ability to change temps fairly quickly.
    either would be a good fit i think , unless one of the other members can suggest a smaller unit with the capabilities you are looking for maybe the cab 50? does it do the on/off thing?
Thread Status:
