Backwoods Savage said:Todd, your 30 minutes is my 5. Most times even less. Sometimes I just go to .25 immediately. It all depends upon the fire.
ok so for the most part if you are burning 24/ 7 you won't have a flame ?Flatbedford said:The flame will go away at low air settings. The cat is making the heat by burning the smoke. It takes a while to get used to the idea of a fire with no flame, but I believe that is when these Stoves are most efficient.
what kind of burn time are you gettingFlatbedford said:Pretty much. You will get a cool northern lights-like thing sometimes for a few minutes and then it just goes away. We just finished our first season with the Fireview, there are others here with much more expertise then I have.
dr.drew said:ok so for the most part if you are burning 24/ 7 you won't have a flame ?Flatbedford said:The flame will go away at low air settings. The cat is making the heat by burning the smoke. It takes a while to get used to the idea of a fire with no flame, but I believe that is when these Stoves are most efficient.
Backwoods Savage said:dr.drew said:ok so for the most part if you are burning 24/ 7 you won't have a flame ?Flatbedford said:The flame will go away at low air settings. The cat is making the heat by burning the smoke. It takes a while to get used to the idea of a fire with no flame, but I believe that is when these Stoves are most efficient.
We have flame most of the time. Early in the burn is where the real fireworks are but then it will die back to a small flame. Yes, sometimes no flame at all but lots of heat as the cat is burning the smoke.
You stated you turned the stove down to 2 then waited 20 min , then set it to 1 waited 20 min, then set it to .05. I have to first ask why did you turn the stove down to 2? You also did not state if this was with the cat on or not.
The only time we turn down to 2 is when we are heating a cold stove up to the 250 stove top temperature and don't want the flue getting too hot or losing all the heat out the chimney. So when we turn the stove down it is almost always down to 1 and then only for a short time (usually not more than 5-10 minutes and most times only a minute or two depending upon the flame). Then we turn down to .25 or .5.
Please remember too that right now you are probably not building the same type of fire you will build next winter so you no doubt are not putting much wood in the stove. Therefore, if running on a higher draft setting a lot of the wood will be burned up by the time you are down to your .5 setting.
dr.drew said:The adjustment lever does not go all the way to 0 . when I set is to 1 it realy is set to .75 any one else notice that with there stove. If set it under 1 the flame will go out .
