    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. HittinSteel Minister of Fire
    Northeastern Ohio
    I recently got an Efco grinder (similar to the oregon 511).
    I have the basics down and have done a few chains with good results.
    Any good tips you long time grinder users can give to us newbies?
    What's the goal with a dressing stone?
    Since this grinder only "cuts" from one side of the wheel, should I flip the wheel over in the grinder after X number of chains to cut from the other side so it wears evenly?
    Thanks guys.
    #1
    Helpful Sponsor Ads!
  2. Lousyweather Minister of Fire
    America
    grinders......I like steak and cheese, myself. When I order them, I ask for everything on it.....the only tips I can give you.
    HittinSteel likes this.
  3. Joful Minister of Fire
    Philadelphia
    "tap, tap, tap" to sharpen. don't plunge it into the tooth and overheat the cutter!
    the dressing stone is for putting a round profile on the wheel, so that it mimics a round file. the wheels are usually a little square in profile, out of the box.
    sometimes you need to make adjustments to the tooth indexing when you flip from one side to the other, since these cheaper machines (and even the expensive ones, for that matter) don't always pivot perfectly.
  4. Bigg_Redd Minister of Fire
    Shelton, WA
    Practice on your friends' chains first
    Realstone, HittinSteel and DexterDay like this.
  5. HittinSteel Minister of Fire
    Northeastern Ohio
    Just did 3 for my buddy..... he said they cut great. Did one of my own and I was not impressed compared to my usual hand filed chain.
    I got a little "beak" on one of the chains....what causes that?
  6. Lousyweather Minister of Fire
    America
    overheating and overgrinding........
  7. Joful Minister of Fire
    Philadelphia
    At the risk of sounding like an amateur (hey... I am), what's a "beak"?
  8. swagler85 Minister of Fire
    NE Ohio
    Ok another question to ask is do I use this to take down the rakes as well? Seems I saw people say they take down the rakes with a dremmel.
  9. Realstone Lord of Fire
    Southern ON
    I'm going to guess (being an amateur myself) a bur on the top of the tooth leftover from filing.
    Joful likes this.
  10. Joful Minister of Fire
    Philadelphia
    Use the grinder to take down the rakers. It's the most consistent and quick tool you have for this job. You can always round off the leading edges with a file afterward, if that's important to you.
  11. MasterMech Minister of Fire
    Hudson Valley NY
    Different size chains will sharpen better with the correct size (thickness) wheel. Make sure you're using the appropriate size wheel.
  12. smokinj Minister of Fire
    Anderson, Indiana
    You just need to shine the cutter very light touch I normally tap 2-3 times. work bench shoes.jpg
    This pic's was awhile back and not so clean anymore. Lighting and magifing glass is Nice!
    Realstone likes this.
  13. Highbeam Minister of Fire
    Looks great smokinj.
    smokinj likes this.
  14. blades Minister of Fire
    WI, Milw
    top tilt of 60-65 per the gauge on back, 30 or 25 for across the front of the cutter. Don't go too deep you do not want to be grinding the tie strap on the other side of the cutter. 1/8" wheel for lo-pro and similar, now for some of the electrics I use apx 5/64 width wheel for those really tiny chains. full size ( like a 72 series) as a 3/16 wheel. With some of the new chain styles you will have experiment a bit to see if the 1/8 or 3/16 is better, but are trying not to get a real deep gullet in the side of the cutter. Yes you can flip the wheel over to wear it a bit more evenly but as the mfg's of the wheels are a bit lax on arbor sizes it really does not help much.If you tighten the cam clamp a bit ( just enough to hold chain steady but still letting slip through) when you do the depth gauges you will get a better grind on them. Get a cheap caliper ( plastic is fine) do not need the dial indicator as you are just going to use it as a gauge to transfer cutter length between the 2 sides. Grind off the tapered knife edges to the point where the 2 flats meet and the narrow down the back side of each jaw a bit so that they will fit between the depth gauge and the cutter. This gives you a quick way to check cutter length for each side rather than taking chain off and trying to hold the 2 cutters together. Hope this helps, Chris
  15. Joful Minister of Fire
    Philadelphia
    What do you guys use on chains calling for 7/32" files? I've been using a 3/16" wheel, but thinking I should find a 7/32" wheel to replace it.
  16. MasterMech Minister of Fire
    Hudson Valley NY
    3/16" is pretty common for 3/8" chain.
    smokinj likes this.
  17. Joful Minister of Fire
    Philadelphia
    It would seem that's the case. Still... a lot of my 3/8" chain calls for a 7/32" file.
  18. smokinj Minister of Fire
    Anderson, Indiana
    File yes stone no......
  19. amateur cutter Minister of Fire
    West Michigan
    I just did an 84dl chisel chain 3/8 pitch with the 1/8th stone & it came out very well. Caveat: the chain got rocked pretty hard, so the cutters were a little past 1/2 gone. A C
  20. Joful Minister of Fire
    Philadelphia
    Hmm... this is all new to me. I always tried to use a wheel of the recommended file size, but it seems that's not what others are doing. How do you choose your wheel size? What's the amount of cutter left have to do with the chosen wheel size?
  21. MasterMech Minister of Fire
    Hudson Valley NY
    The file diameter determines the depth of sharpening on the cutter. (Did that make any sense?) The stone width doesn't have to be exactly the same because the depth of the cut is determined by a setting on the grinding machine.
  22. Realstone Lord of Fire
    Southern ON
    So much to learn! Side question: If I file my rakers down a little more than recomended, can I determine how aggressive the saw cuts by how much pressure I apply to the bar? IMO, that might be useful when cutting both hardwood & softwood.
  23. smokinj Minister of Fire
    Anderson, Indiana
    Yes you can but if your riding with rakers lower than they should be then your going to need a very light hand and if your filing them flat can make for a bumpy ride! Stock height you will be able to even tune the saw by purssre though out the whole cut. Most cant hear where a saw should be but once you have it your golden!
  24. Highbeam Minister of Fire
    That's why you don't go back and forth from file to grinder. Pick one and stay. You'll waste lots of chain otherwise. The stone will have a specific contour that can't be perfectly round like a file. Every time you recontour the tooth to the new sharpening device you waste metal.
    The remaining amount of tooth on the chain makes no difference. You will waste some of the remainder converting to the wonderful world of grinding but throw the hand file away. Bring two or more chains with you to the woods instead and just swap as needed. I can easily get a cord of wood on one chain.
  25. amateur cutter Minister of Fire
    West Michigan
    The teeth or cutters slope upward by necessity to make the edge the high point. As the cutter gets sharpened & cut back it gets shorter, thus lowering the height & gullet size. Same reason the rakers need to be lowered slightly after a few sharpenings. A 3/8 pitch chain will have almost exactly the same height cutter @ the 1/2 way point of it's life as a new .325 pitch chain does . Hence the reason for the smaller diameter file as the chain gets toward the last 1/2 to 1/3 of it's life. I tried the 1/8th wheel for kicks just to see how it did, & was very pleasantly surprised @ how sharp the chain came out. Cut very well today too. I just play around with stones & angles a little to see what I get. If someone is paying me to sharpen a chain, it goes to original angles. My own chains get tweaked a little here & there for my preferences. I run short bars on big cc power heads, so I like a real aggressive fast cutting chain. A C
