Tips on insulating around garage door tracks
Post in 'DIY and General non-hearth advice' started by Green Mtn Boy, Jan 5, 2009.
Thread Status:
  1. Green Mtn Boy
    Green Mtn Boy
    Expand Collapse
    Nov 19, 2008
    25
    0
    Loc:
    Northern Vermont
    Just wondering if anyone has any tricks for a better way to insulate around the tracks of a garage door. I can hear the wind whistle through on a windy day. I believe it's coming from in between the door panels where they bend and also at the very bottom of the door. I have heavy duty garage door weather stripping on the outside of the door but they have a barn door look so it doesn't contact directly on the door but instead on the band board. My first thought was to build a small wall around each side and insulated it but was looking for other ideas to incorporate.
    Collapse Signature Expand Signature
    Helpful Sponsor Ads!
  2. Dune
    Dune
    Expand Collapse
    Jan 14, 2008
    3,128
    273
    Loc:
    Commonwealth Of Massachussetts
    You can buy this stuff that looks like trim board, which has a nice gasket made into it for the sides. Also if you look at the track, you will see that it can be adjusted to bring the door closer or further from the wall. As for the bottom of the door, there is a product avaiable for that as well, it mounts on the bottom of the door.
  3. d.n.f.
    d.n.f.
    Expand Collapse
    Dec 14, 2007
    504
    1
    Loc:
    Nelson BC
    You say it is coming in where the panels bend. So it is not a big one piece door.
    Then why not put some of that sticky one side foam strip tape (get thin) and apply it along the top of each door panels. So you would need a lot of tape (each panel section will need a strip). Should act as a draftstop.
    I have the problem on the sides of the door. Will look into what was mentioned above.
Thread Status:
