I've had 5 different hearth/chimney contractors come to the house and inspect the fireplace/remainder of the chimney that came with the house. The previous owners removed the chimney below the roof line after they had a chimney fire.
Chimney guy #1 (CSIA) wants $3100 to do a 6" SS liner with thermix in the existing masonry and then rebuild the chimney with masonry to the required height
Chimney guy #2 says he won't do the job due to possible structural issue related to the chimney fire that cannot be seen without tearing fireplace apart. (This guy seemed annoyed the entire time, never introduced himself nor shook my hand which I must say is a first for a contractor coming by the house)
Fireplace store guy quotes $3100 to do a 6" SS liner with thermix and a class A from the existing masonry to the required height
Chimney guy #3 off hand quotes $15000... Not sure why, but also had a less than great BBB rating so we simply parted ways.
Chimney guy #4 (NCSG) quotes $3000 to do a 6" SS line to the top of existing masonry and then do a class A from there, build SS chase and put siding on it.
So the decision is really between #1 and #4, but #4 didn't state using thermix. The masonry section is probably 12' and the class A section would be another 12'. Is thermix really necessary? If so I'll ask him to revise his quote to include using it. I assume once you pour that down your flue it and the liner are there forever. As for the chimney it starts in the basement and the goes up the "outside" wall through a 3 season room (unheated) before it comes out the roof. Is that considered an exterior chimney then since the room is unheated. The masonry in that room is framed around/drywalled over so its difficult to say what condition it is in. They did say the clay tiles are intact.
