I have an outside wall chimney some 25' and is a straight shot down a 12x12 clay flue (minus the smoke shelf, of course)
I have on order a new 3 Cu. Ft. insert promoted up to a whopping 97k btu rating!
I want to make sure the new liner install will hold up to the years of future burns and I can sit back with my hot coco as I thank you guys for such a wonderful site.
I'd like to ask you guys a few questions regarding my new insert installation, I hope you don't mind, it's in regard to utilizing rigid pipe.
I was looking at a lot of posts regarding the pros and cons dealing with the installation of rigid lining for the above application.
I was looking a BrotherBarts' picture of his offset posted some time ago so I did some digging through the archives. I'm not sure if anyone or anything has changed their opinion or the rules since then.
From what I was able to glean, I've found double wall and triple wall rigid pipe.
First of all, is rigid what they consider "class A" pipe?
Since my chimney has no offsets, would you guys lean towards going with rigid instead of flex? if rigid, what would be favorably recommended? would I buy double wall or triple wall? do I also insulate rigid just as a flex liner since it's an outside chimney ?
Is there a connector needed at the bottom of the straight run of rigid to mate to either a 45 or 30 deg. offset that connects to the top of the insert?
Then there's all the connections every 4'... do I slather cement at each junction or what?
I really want to do the right thing for this rather large and high heat output insert . It is my understanding that rigid wall pipe is by far thicker than flexible liner so I'm guessing that it'll either last longer or take longer and hotter burn cycles.
The wealth of knowledge found here is very valuable. So thanks in advance for your feedback
I know I can use thinner flex the whole way down but...??? what about Rigid (I'm so confused )
Is rigid the right choice for this application? Did I supply enough info?
