    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. LovesWood New Member
    I just bought a used Tremont woodburning fireplace insert. the problem is that it did not come with the metal pieces that bolt to the sides and top of the insert and seal the fireplace around the insert. first I need to know what these pieces are called, and secondly, where can I find these pieces to fit my insert?
    #1
    Helpful Sponsor Ads!
  2. elkimmeg Banned
    That 70's type of insert cannot be installed per modern codes, it has to be vented 1/2 way up the first flue liner The damper must be removed and the damper area metal plated to block off room air from escaping up the chimney, or back drafting exhaust containing Carbon momoxides. The face seal insert proved not to be all that safe as the seal often did not do its job. All to often exhaut gasses leaked into the living space. I would highly recomend that, you never install that stove. It is my oppinion it is unsafe to opperate. The risk is too great concerning your safety. You will never get a permit so it would have to be installed illegally.
  3. LovesWood New Member
    Thanks for your informative reply. I will heed your advice. I sure am glad I found this forum!!
Thread Status:
