Trying to program Lux TX1500ub with pellet stove
Bugs5144
1
Canada
I am trying to program a TX1500ub with a Lennox Montage 32FS. The issue is the thermostat has a cycling feature and when in heat mode the pellet stove turns on/cycles every 10 minutes. I have set my jumper on the back to ELEC. And I set the setting to FURN. on the thermostat.....
TO ACCESS THE SETUP MENU: Move the System Mode switch into the OFF
position, and then hold down the EMER button for approximately 5 seconds until
the screen changes.
The menu will always start with item #1, and is advanced to
each following item by a single press of the NEXT button. The options for each
item are changed using the UP or DOWN buttons.
Goto ITEM #08, set it at either 60 or 30
30 will cycle 2 times an hour 60 will cycle one an hour.
