Ugh..orangeburg pipe...dilemma and septic question
eclecticcottage Posted By eclecticcottage, Aug 16, 2013 at 10:14 AM
Thread Status:
  1. eclecticcottage
    eclecticcottage
    Minister of Fire 2.
    NULL
    Dec 7, 2011
    1,794
    343
    Loc:
    WNY
    So, we have Orangeburg pipe (or another similar brand) leading from cast iron to the septic tank. Well...some smart person put some concrete for a post on part of it many years ago. Guess what that did (several holes and it's now oval instead of round)? I can't believe we didn't find it sooner. But now...we need to replace it. Rather than try to fix the orangeburg we're replacing it, although what we have dug so far, aside from the part squashed by the concrete appeared to be in pretty good shape still. Considering it's PAST it's 50 year lifespan, I guess that's pretty good-although I wish it had reached and exceeded it about 5 or 6 years ago so someone else could have this fun task (even though we bought the place 2 years ago it was vacant for a few years, so I am thinking about 5-6 year would have landed it while it was still occupied). Oh well.
    Now. The problem. How the heck was this stuff attached to cast iron? We aren't ready to replace that YET and don't really want to break it. That goes into the slab, and is the waste line from the only bathroom. Since this fun all decided to occur this year, our Old House is rented, so we can't just go live there again for a little while we complete this task. We might be able to use the neighbor's house at some point later when we do the cast iron, at least for bathroom, but that's hopefully for later.
    Also...anyone know how many 90 degree angles can be in a main sewer line? If we have to redo the cast iron there'd be at least one, and possibly two, if we can leave it there would be three-this dang pipe was run UNDER a room and we'd rather not leave it that way, because we have to break up a bunch of concrete if we do.
    Then we need to figure out how to connect PVC to the cast iron. I am leary of that cast iron, I know it's probably 60 years old and brittle....
    Another weird problem...it seems the inlet on the septic tank is LOWER than the outlet. Does this seem right? The tank isn't crooked (like it settled funny), it just looks like it was made this way. I'm not home to see this, I'm getting a play by play from DH on this. I guess there are tubes in the tank leading to the outlet which is near the top of the tank. Could this actually be backwards (like someone put the in at the out and the out at the in)?? Are there maybe two outlet pipes, one lower than the other (kind of like the extra drains in sinks and tubs to catch over flow in case of a clog in the main drain)? This is very likely the original 1950's tank, considering the orangeburg ran to this tank. This is our first foray into the world of septic, previously the Old House had sewer service and someone had already replaced the main line out with PVC before we bought it (although the stack...ugh..is still cast iron).
  2. lukem
    lukem
    Minister of Fire 2.
    NULL
    Jan 12, 2010
    3,687
    1,518
    Loc:
    Indiana
    Fernco fitting.
    f3cbboy and PapaDave like this.
  3. eclecticcottage
    eclecticcottage
    Minister of Fire 2.
    NULL
    Dec 7, 2011
    1,794
    343
    Loc:
    WNY
    Um...ok. I know what it is...I assume you mean to use that once we get the orangeburg off of the cast iron to attach the new pvc?
    I'll have to post a pic, I don't know how it's set up but currently the orangeburg is connected to a cast iron T with one of the ends...erm..."capped" with what appears to be a clay flower pot. Will the fernco connect at a cast T?
  4. lukem
    lukem
    Minister of Fire 2.
    NULL
    Jan 12, 2010
    3,687
    1,518
    Loc:
    Indiana
    Get rid of all the old junk pipe and use a Fernco to connect PVC to cast. I did this except it was clay tile instead of cast.
  5. lukem
    lukem
    Minister of Fire 2.
    NULL
    Jan 12, 2010
    3,687
    1,518
    Loc:
    Indiana
    Weird. I had a capped too Tee and just replaced the whole thing with a couple 45s.
  6. USMC80
    USMC80
    Minister of Fire 2.
    NULL
    Mar 27, 2013
    842
    389
    Loc:
    New Jersey
    a 1056 series fernco will get you from cast to pvs
  7. eclecticcottage
    eclecticcottage
    Minister of Fire 2.
    NULL
    Dec 7, 2011
    1,794
    343
    Loc:
    WNY
    Good deal. We definately plan to get rid of the orangeburg. It's just a matter of how we're routing the replacement pvc.
    Now anyone know how to get the orangeburg off the cast? I really don't want to disturb the cast yet. I've never heard of Orangeburg pipe before digging this up, but I can't figure out how they would seal it, unless they used pitch or tar or something. Unless it's just a tight fit-we haven't messed with that part yet.
    Any guesses on the inlet/outlet? I guess there is some sort of system that does use two pipes at the outlet (I found a diagram of it) but I don't know how common it is or when it came into use.
    Blah. and I thought we'd get the laundry room fixed up this coming week so we could relocate the washer and dryer out of the living room to where they should be (we're making a small room into a laundry room, it wasn't before-so there's still all that plumbing to deal with).
  8. Butcher
    Butcher
    Minister of Fire 2.
    NULL
    Nov 2, 2011
    530
    364
    Loc:
    N. central Ia.
    Are you doing this yourself or having it done by a plumber? Take a good look at that cast pipe also. It will, over time, begin to flake and expand on the inside thus plugging the line. BTDT. Might want to bite the bullet and put all new PVC in if the budget allows it. In our old farm house we used to live in we had constant sewer problems. Dug up the tank. It was a 500 gallon metal barrel with 4x8 timbers for a lid. There was 6 feet of cast on the outlet side that connected to orangeburg that then ran to plastic field tile. The orangeburg was in good shape after all those years but the piece of cast was corroded almost shut. Replaced the cast with PVC and 2 fernco fittings and all was right again.
  9. eclecticcottage
    eclecticcottage
    Minister of Fire 2.
    NULL
    Dec 7, 2011
    1,794
    343
    Loc:
    WNY
    DIY. Plumbers are not in the budget. We do plan to replace the cast, but we are hoping to do so at a later date. We're on a slab and to replace it we'll have to tear out the floor in the bathroom, break up the slab from the toilet to the outside, then replumb. Not impossible but messy and not what we want to do at the moment. Also, that is the only bathroom here so that would be something I'd want to do while I was on vacation and we'd also need to work with our neighbors so we could use their bathroom, or something. We hadn't planned to rent our old house out yet but friends lost their lease so we got them in there earleir this year-othewise we could just do all of the work now in one fell swoop and just move back to the old house for a little bit while we did it all.
  10. 343amc
    343amc
    Feeling the Heat 2.
    NULL
    Nov 23, 2005
    375
    181
    Loc:
    West Michigan
    I feel your pain. The same thing happened to me summer of 2003. I dug up the Orangeburg pipe, ripped out all the cast iron and replaced it with PVC. I got lucky in that my bathrooms are directly above where the main drain leaves my house and heads to the septic, and I'd already replaced the galvanized pipe that came from the kitchen with PVC the year before. My cast iron drain was about half plugged anyways.
    While I haven't spent much time looking in septic tanks, I'd presume the outlet baffle needs to be at least slightly lower than the inlet baffle to keep the outlet below the scum layer. It might be hard to tell unless the tank is empty.
  11. Michael Golden
    Michael Golden
    Feeling the Heat 2.
    NULL
    May 17, 2012
    291
    59
    Loc:
    Ohio
    I would use a fernco fitting like said above. I haven't seen a lot of septic tanks, but the ones I have the inlet is always above the outlet. The oldest tank I've seen has been my parents concrete tank and it was put in in the 70's.
  12. DJB
    DJB
    New Member 2.
    NULL
    Jan 16, 2013
    12
    19
    Loc:
    Marshfield, MA
    The orangeburg could be attached to the cast either with a 'burg coupling that fits over the cast, or just butted up against each other, with a glob of cement holding them together. if its a coupling, slice it the long way with a grinder or a chisel or whatever you may have, then peel it open, sort of like a clamshell. if it's cement, just whack it with a hammer or a chisel, it should break before the cast. I've seen old cast that's rotten and falling apart that breaks when you hit it with a shovel, and I've seen it that's still as good as new. Different brands, I guess. Just because it's old, doesn't mean its junk. When you open up the connection, look inside, clean it out with a stick, and check how thick it is, that will tell you if it's worth replacing. There's a few different sizes of 4" fernco, if there's a ridge on the end of the tee that your hooking onto, you may need one of the bigger ones. When your running the new line, try to stay away from 90's , use 45's instead, with a cleanout at every 90 degrees. As far as the tank goes... if the inlet is lower than the outlet, that would mean that the inlet pipe is under water. Is that the case? is it possible that there is more than one inlet, rather that outlets? pipes can settle outside of the tank, if the outlet was to settle just outside of the tank, that would lift the pipe up inside the tank, making the outlet higher. There's a lot that could be going on. back in the old days, you could pretty much do whatever you wanted. If you can put some pictures up, I could get a better idea of what's going on. BTW, I am in the septic repair and installation business, so I see this s@*t everyday.
  13. eclecticcottage
    eclecticcottage
    Minister of Fire 2.
    NULL
    Dec 7, 2011
    1,794
    343
    Loc:
    WNY
    Super quick update-orangeburg is out, was just slid over the cast (whew).
    Yes, inlet has water in it...which is partly how we found the problem. I don't think the outlet is lower now that I've looked, but we have to dig out that side of the tank. The water is too high though so theres' a clog somewhere I think, in the outlet/after. We're going to have it pumped, if we have to redig/replace the lines to the leach field so be it. Probably tree roots, we de-rooted a bunch of lines for our drainage system about a month ago so it wouldn't be a surprise.
    Cast is meh, we'll replace later.
    Trying to find correct pipe/fitting to go into the tank, then pitch from the cast to the tank since the orangeburg was squished by two concrete pads and the post...
  14. Ehouse
    Ehouse
    Minister of Fire 2.
    NULL
    Jul 22, 2011
    906
    256
    Loc:
    Upstate NY
    Cast is not hard to cut with a sawzall ( fine tooth) or even a hack saw.
  15. schlot
    schlot
    Minister of Fire 2.
    NULL
    Nov 21, 2011
    771
    490
    Loc:
    Iowa
    That cast will be brittle so becareful. Also try to use 2 45degree bends instead of a 90 if possible and I'd put a cleanout where you make that sharp of bend
  16. Ehouse
    Ehouse
    Minister of Fire 2.
    NULL
    Jul 22, 2011
    906
    256
    Loc:
    Upstate NY
    A sweep 90 might work also.
  17. StihlHead
    StihlHead
    Guest 2.
    NULL
    Why PVC and not ABS? Most of the septic and sewers here in the west have black ABS piping. As for Orangeburg (bitumenized fiber conduit) I saw that stuff a lot in California. Amazing that they let that stuff be used for so long.
  18. firefighterjake
    firefighterjake
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    17,638
    3,900
    Loc:
    Unity/Bangor, Maine
    Playing in the poo . . . been there, done that . . . last year. With me it was a case where the home owner used the flimsy gray pipe and over time it got crushed which meant a couple times per year I would have to go out, pop the cover to the septic tank and ram some black plastic pipe to unblock it. Last year we dug things up and replaced the section with PVC . . . so far, so good. Still a nasty, smelly job.
  19. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,851
    8,616
    Loc:
    South Puget Sound, WA
    That explains your fertile imagination Jake. ;lol
    firefighterjake likes this.
  20. eclecticcottage
    eclecticcottage
    Minister of Fire 2.
    NULL
    Dec 7, 2011
    1,794
    343
    Loc:
    WNY
    All done and used two 22 1/2" angles-just broke up the concrete instead of going around it.
    Not the most fun job we've done here so far, but now it's done.
  21. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,346
    2,089
    Loc:
    Cascade Foothills, WA
    A lot of people are confused when they look inside a septic tank. I hear, "It's full" a lot since people don't realize that it is supposed to be full. The inlet and outlet are supposed to be even. You should not get liquid setting in the inlet pipe but what the heck, it will work fine and things sometimes settle an inch or two.
    It may be poo to you but it's my bread and butter. I'm in the poop business too but I use calculators more than shovels.
    DJB likes this.
  22. eclecticcottage
    eclecticcottage
    Minister of Fire 2.
    NULL
    Dec 7, 2011
    1,794
    343
    Loc:
    WNY
    Lol at the full part. Um, the water and uh..stuff...can't go anywhere if it's below the outlet (I do know all that's supposed to be leaving is liquid). We want ours pumped just because we don't know when it was last done, so there's no telling how much sludge there is.
  23. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,346
    2,089
    Loc:
    Nothing wrong with pumping but there are ways to determine sludge and scum layer thicknesses. There is a tool called the "sludge judge" that is pretty much just a clear plastic straw that is rigid. You shove the judge to the bottom and then block the top and lift out the full straw which is like a core of the tank and you can measure layers. Or you can just shove a 2x4 in and feel for the mud.
    When in doubt, pump it out. Sending junk down your drainfield laterals can ruin your drainfield.
  24. Retired Guy
    Retired Guy
    Minister of Fire 2.
    NULL
    Oct 27, 2011
    506
    132
    Loc:
    Cape Vincent, NY
    We put in a new system a couple years ago - new field, dosing tank with a flout system. I can appreciate the Bread and Butter comment.
Thread Status:
