United States Stove Medium Wood Stove
It will heat a well insulated 2,000 sq. ft. room with eight foot ceilings and just four walls in a moderate climate.
2 cu ft firebox. Probably 1500 sqft in your climate with average insulation. Less if it is drafty, more if it is well insulated.
I was looking at that stove at a True Value. It's a good value, be aware that it requires a large and heavily insulated hearth. You need the hearth to extend 26" in front of the stove and it needs to have a R of 1.2. If you were to only use Durock as a hearth it would be 4 sheets thick.
