Hello everyone, in case anyone was wondering NSPS (stands for “New Source Performance Standardâ€) also known as the “EPA Wood Stove Certification Program†review is coming to a close. It was first promulgated in 1988 and has not been revised since that time.
Therefore the EPA had a mandate to update its standards. Currently a "EPA cerified stove" was one that would release less than 7.6 grams per hour of particulate matters. EPA’s new goals is to Lower emissions limits based on current “Best Demonstrated Technology†(BDT). They also want to regulate previously exempted appliances. Those include: Central systems (furnaces and boilers) – wood and pellet; Pellet stoves/inserts; Coal stoves/inserts; Decorative wood fireplaces
What will the new standard be? For wood stoves and inserts, the new limit will be 4.5g/h or lower. Same for pellet stoves & inserts. For central systems, EPA will likely use a measure of emissions that takes into consideration the heat output, such as g/MJ or g/MBtu. For decorative wood fireplaces, EPA will probably adopt the current EPA Low Mass Voluntary Program, with emissions at the phase II level (5.1 g/kg). Coal stoves: not determined if any.
Timing is expected as follows: Proposed NSPS Revision: Summer 2011. NSPS Promulgation: September 2012. Compliance at Washington State level (wood/pellet stoves): Could be 60 days after promulgation (so Fall 2012 at the earliest). Retailers will be given at least one year (possibly two) to clear inventory.
Â
To a certain extent, this is good news for everyone. Cleaner air for all of us. Also most manufacturers should be able to meet new emission standards and deadlines.
If you are in the industry, join HPBA as it give you a voice in the industry. For the rest of us HPBA is chock full of information on the subject.
Â
