    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. MCPO Minister of Fire
    I see that at least one stove maker recommends foil tape on all pellet vent pipe joints but I also know that it isn`t actually code approved to seal flue gases and smoke . I understand that eventually it could bake off. I also read that the adhesive gives off a sickening smell.
    I did tape mine basically to cover the black Hi temp silicone joint sealer . That said , I do see a lot of it used on gas vent piping.(B vent?)
    I`d sure like to hear opinions based on experience or technical knowledge (or both).
    Thanks,
    John
    #1
    Helpful Sponsor Ads!
  2. flueinc New Member
    porter me.
    Tape is not a fix for a bad seal. If you use a good sealing pipe like icc excel pellet pipe it does not leek.
  3. Metal Minister of Fire
    On Type L-Vent you are using the tape to stop fly ash from getting out at the joints, not to "seal" the pipe. Type L Vent is made for negative or neutral pressure systems and therefore doesn't require an airtight seal.
  4. drizler Minister of Fire
    Chazy, NY 12921
    Just get a tube of ORANGE hi temp RTV from Auto Zone or Advance or some other car place. I just put a smear on my male pipe section when it goes together and that will take care of any little leakage you will encounter. If you can't get at it to get it apart you can just smear it around the joint with your finger and it should do the trick nearly as well. Keep it simple.............................................
  5. flueinc New Member
    porter me.
    with excel pellet pipe you do not get leaks you do not need tape or silicon to stop leaks.
  6. drizler Minister of Fire
    Chazy, NY 12921
    Probably true enough but for one big thing. Why buy new pipe when you already have it. No offense but thats a government style solution, spend $300 to do the same job you can do with about $1.00 worth of silicon that is unfortunately red in color. If you want to bother you can hide that too by smearing it on the male section and twisting it together then wiping the visible portion off like you were glueing a plactic pipe. That and / or a tad of silver high temp paint from the local car parts place.
    Ah 300 -400 vs. 3 bucks what to do. Its your money. I watch the stupid government I work for do this sort of foolishness all the time and its purely pitiful. Personally I always go with the "keep it simple stupid " approach. For some reason its always the best solution to already simple problems.
  7. Shane Minister of Fire
    Casper Wyoming
    You dont' even have to get orange rtv. Stove shops will have black. It's 550 not 650 like the orange but on pellet vent that won't matter. The foil tape will probably work too. I always hated how it looked and in addition your stuck painting it inside.
  8. Corie New Member
    Halifax, VA
    If the foil tape gets hot enough, the adhesive does have a rather terrible smell. I'd avoid using it in all but emergency repair situations, as it will let go over time anyway.
  9. stoveguy2esw Minister of Fire
    madison hgts. va
    i have simpson pipe type L connecting my pellet stove to my 6"flue , i didnt caulk the joints , just the coupler at the stove, the bottom of the tee cap (not where it untwists but the actual bottom) and at the thimble with black 550F silicone , i have no leaks whatsoever.
    as a sidebar, if you do caulk your pipe joints and cannot get them apart to clean them , get 2 "strap type" oil filter wrenches , does wonders getting tough pipe connections untwisted.
  10. drizler Minister of Fire
    Chazy, NY 12921
    The one place I was getting a tad of smoke from mine and I do mean just a tad was the back of the stove. Right where the first section of pipe slides straight into the pipe projecting out the back. I just took that section of pipe and the other small one that disappears into the wall thimbal and put a small smear of orange RTV on there and twisted them together. It doesn't take much to do the deed just like on a car. The way that Simpson duravent goes together it pretty much makes its own seal. The stuff is well built to say the least. My stove probably started leaking from getting bumped around over the years.
Thread Status:
