    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    I have a stove that is equipped with a damper. Should control the heat with this instead of the air supply.
    Answer:
    Use both. The damper is commonly used after the wood has burned down to embers. Closing it partially at this point will hold the heat into the stove for a longer period of time.
    If you have a newer EPA rated stove that damper might be a bypass damper. If so then you would want to close the damper entirely when the stove reaches temperature. Try to locate a manual for your stove and read the burning tips and articles at the Hearth.com information page.
    Link: Hearth.com Information Page
    #1
    Helpful Sponsor Ads!
Thread Status:
