using a doggy door on an interior door.
bryan Posted By bryan, Oct 17, 2013 at 11:15 AM
Thread Status:
  1. bryan
    bryan
    Member 2.
    NULL
    Aug 10, 2012
    106
    21
    Loc:
    Wilmington, DE
    We recently got two cats. Obvious there needs to a litter box but the question is where to keep it. It is currently located in a spare bedroom but that won't work long term. The best options are in unfinished parts of the basement. While this is a non-issue during warm weather it will be once it finally gets cold here. I heat from the finished part of the basement and simply keep the doors shut to the unfinished areas. For reasons that have been innumerably stated on this site I'd rather not try to have my precious heat flowing into an uninsulated area. I'm thinking of putting a doggy door into an interior door that way there is an opening but one thats low to ground. It would let the cats into the unfinished area and keep the hot air out. I may finish/insulate the room in the future, but its much lower on the honey do list. Sound like good idea?
  2. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,828
    9,891
    Loc:
    Northern Virginia
    It'll work fine. My cat's box is in the unfinished basement and the goes to it and back through a pet door in the basement door. Just leave a low watt light on the other side so the cat can see that no surprises are waiting for them on the other side.
  3. fossil
    fossil
    Accidental Moderator 2.
    NULL
    Staff Member
    Sep 30, 2007
    10,552
    2,421
    Loc:
    Bend, OR
    I've done that two ways. In Virginia I cut, framed, and finished a little passageway for them right through an interior wall. Out here in Oregon, I installed a commercial (pet store) cat door in an interior door. Both ways worked fine. Rick
  4. maverick06
    maverick06
    Minister of Fire 2.
    NULL
    Sep 27, 2008
    771
    42
    Loc:
    media, pa
    I cut a hole in an interior door for my 2 cats. simply a U shape cut at the bottom (clear to the floor) and framed the inside. I was surprised how much reinforcement is in the door, no problems with it at all.
    The cats took right to it and it does look pretty nice
    For what its worth, their litter box is in the basement, and i keep the light off, they have a good walk down there, lots of obstacles, and have had no problems for years. But cats can be finicky, if you leave a light on, go get an LED bulb!
  5. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,828
    9,891
    Loc:
    Northern Virginia
    Yeah. Mine spent the first year of her life fending for herself in the woods until I lured her in. Took months to get the trust thing going. So she is careful. The 13 watt curly thing at the base of the stairs is worth it.
  6. gzecc
    gzecc
    Minister of Fire 2.
    NULL
    Sep 24, 2008
    4,458
    870
    Loc:
    NNJ
    If its a hollow door be prepared with appropriate sized interior frame pieces to fit into the doors hollow core. Glue should suffice.
  7. velvetfoot
    velvetfoot
    Minister of Fire 2.
    NULL
    Dec 5, 2005
    9,447
    716
    Loc:
    Sand Lake, NY
    I put in a kitty door to the basement steps. What I did was put it in the wall next to the top step. That way there isn't as big a step as there would have been with the kitty door in the door, plus it was easier to put in.
  8. bryan
    bryan
    Member 2.
    NULL
    Aug 10, 2012
    106
    21
    Loc:
    Wilmington, DE
    Thanks for the replies. Sounds like a pet door it will be. Thankfully I don't have door/stairs combination, just a door in a basement hallway. I am sure that the door is hollow so I'll cut some pieces to frame out the inside of it if needed.
    I have some old 40 watt equivalent CFL bulbs that will fit this duty well. They are old ones from IKEA that take 5 minutes to warm up so they've been banished from all the other fixtures in the house. One of those babies should do the trick just fine. That or I'll get another LED night light
  9. semipro
    semipro
    Minister of Fire 2.
    NULL
    Jan 12, 2009
    3,119
    490
    Loc:
    SW Virginia
    We're trying to toilet train our cat.
    Its been interesting to say the least what with the influences of dogs and children.
    We may be installing a access door in our basement if it doesn't work out.
  10. drewmo
    drewmo
    Feeling the Heat 2.
    NULL
    Nov 20, 2006
    325
    66
    Loc:
    Central Maine
    We did the exact thing last year and very much appreciate the cat doing its business outside of our living area. If you have the option to check out a couple of cat door models, I'd look for the one with the tightest fit/closure. Our cat door isn't exactly airtight and I'm not sure we could get any better than we did. But I wish I had shopped around a bit.
  11. TradEddie
    TradEddie
    Minister of Fire 2.
    NULL
    Jan 24, 2012
    823
    226
    Loc:
    SE PA
    I can't believe we waited a year to move the litter tray downstairs. You can get cat doors that are much smaller than dog doors, but just accept that it isn't a draft proof seal in the door. I have an LED nightlight just above the tray, but the basement has windows too.
    TE
Thread Status:
