- Oct 21, 2011
- 28
Bought a tube of chimney pipe caulk to use on the black pipes. Was told they will leak smoke if I don't caulk them. I'm using the wood burner in a 5 x 7 foot sauna, so it is a small area and don't wnat lots of smoke in it.
What is the neatest way to apply caulk? Should it be put on both male and female pipe ends? Or just coat the inner part of the female pipe? They also sold tubs of it, but I figured a caulk tube would be neater.
Once pipes are caulked, should they be screwed together? If so, how many screws to do you put in each pipe joint?
Thanks
Thanks
