using old insert for hot water
Byrond Posted By Byrond, May 15, 2013 at 9:51 AM
  1. Byrond
    Byrond
    Member 2.
    NULL
    Apr 3, 2013
    119
    31
    Loc:
    Pumpkintown SC
    I have an old craft insert that i would like to use for heating hot water for showers/ laundry and other not potable uses. I wa hoping someone could maybe provide a few ideas as to where to start nd what materials are needed. Maybe a link or two. I know it will not be verg efficient but our houshold uses roughly 90 gallons per day of hot water. If there is a way i may look at piping the water into the air handler at some point.
  2. BoilerMan
    BoilerMan
    Minister of Fire 2.
    NULL
    Apr 16, 2012
    1,717
    325
    Loc:
    Northern Maine
    Have you looked into some type of DIY solar? 90 gal/day in the summer is alot, solar or even a heat pump water heater may be a good payback and produce the hot water you need.
    TS
  3. Byrond
    Byrond
    Member 2.
    NULL
    Apr 3, 2013
    119
    31
    Loc:
    Pumpkintown SC
    Hadnt. Thought of solar. I just thought with this old sto sitting around that i woul check oht the possibilities. wa thinking of fabing an insulation jacket and running a series of tubues inbetween and usint that to heat a 250 gallon storage tank via a heat exchanger. Another thought was to us it for a whiskey still.
  4. BoilerMan
    BoilerMan
    Minister of Fire 2.
    NULL
    Apr 16, 2012
    1,717
    325
    Loc:
    Northern Maine
    I think you may have some overheating issues with tubing and insulation around a wood stove. You may also expierence the water flashing to steam and cavitating your circulator. I've been looking into a Geyser heat pump water heater, you could use it with your existing tank, they say they are well built.
    TS
  5. Byrond
    Byrond
    Member 2.
    NULL
    Apr 3, 2013
    119
    31
    Loc:
    Pumpkintown SC
    probably could use it. How would i go about preventing the flashing of the water/ overheat issues? I am ckueless to this boiler stuff. I am just trying to learn enough to get me in trouble. This would be a very basic system. I would like to build a fire in the evening o that during the night so that the storage tank would be hot enough for a shower in the am. I presume that it would hold enough heat throughout the day to do laundry and dishes but i am not sure.
  6. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    Unfortunately - a proper system is not all that "simple". Safety features MUST be included. A system that is NOT proper is called a bomb. When dealing with a pressurized system, as you are (as opposed to open air), pop off valves, circulator pumps, thermos, etc. are the norm.
    BoilerMan likes this.
  7. Byrond
    Byrond
    Member 2.
    NULL
    Apr 3, 2013
    119
    31
    Loc:
    Pumpkintown SC
    I do have an understanding of safety and all. At work i maintain 11 water source heatpumps with 2 gas boilers. Our loop is completely computer controlled. I would keep everyrhing outside the house. I guess my main question is that can an outdoor woodstove supply enough heat to heat a storage vessel, say 250 gallons, to a comfortable temp? I m looking for a starting point to be able to create a loop that would use a water to water heat ex to then heat storage water. I also would like to install. Is thi doable? Or could this be made into a open no pressure system? Im not really looking for peak percormance, just a project
  8. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    Are you saying that you are going to use the old insert - outside? Now I am getting the picture. Sure it can be done, but as you state above...it will be very inefficient. I know this from first hand knowledge. I built an open loop heater for a swimming pool out of an old stove. The amount of wood consumption was crazy.
