VC Encore Pipe Adapter
singletrack70
1
Maine
Hi folks,
I recently had a chimney fire, thankfully the only damage was my masonry tile liner which is now cracked. My only real option at this point in the season is to go with a SS 6" liner. I have a 25' chimney, which will accomodate the liner nicely, but my stove, a VC Encore 2550 (cat) is set up with a 8" oval collar. Previously I just had run an 8" oval to round adapter off the collar (rear exit) to 8" double pipe, straight into the chimney. I believe Encore makes a 6" round cast iron collar that I can swap for the current setup, but I am wondering if I can just use a reducer from the 8" oval adapter to a new piece of 6" double pipe into the thimble and liner.
Any thoughts?
Thanks,
Crusty
Sounds like it should work ok as long as you are not running the stove open with a screen at any time.
