VC Montepelier fan speed control
Brae09
10
Oregon
A quick question about the Montpelier. I couldn't find the answer from the literature. Is the fan speed automatically adjusted only? Can you manually control the maximum fan speed? Thanks!
The fan is automatic only for off/on. Fan speed is up to you. I run mine at the 3:00 position.
Gabe
Like he said, you manually adjust it after it initially turns on, but you do have to turn it to the on position if it is turned off. It will also automatically turn off when the unit cools down.
I'm noticing for best heating results, I start with the fan on low, for the first hour or two, then I turn it all the way up with a hot fire (air completely closed or to the right) I get my space to 76 degrees.....
