    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Verynycegirl New Member
    Massachusetts
    I have wall vents for my heating system....which of course I'm not using. They have the little levers you can use to close them but I still can feel tons of cold air coming through them. Do they sell some sort of vent cover? I did find magnetic ones to use with floor vents, but I need something that would work with wall vents. Any ideas short of using every towel in my house to cover them??
    Tracy
    #1
    Helpful Sponsor Ads!
  2. elkimmeg Banned
  3. Roospike New Member
    Eastern Nebraska
    I think that is the Magnetic cover she was talking about . I dont know of any other covers but thoes myself. My thought would be to take the vent off and put plastic behind the cover . kinda of PITA i would think .
  4. Chuck Pearson Member
    Adrian, MI
    My wall vents are metal and the magnetic covers work fine. Have you tried a magnetic cover?
  5. Willhound New Member
    Northern Ontario, Canada
    You can buy sheets of flexible magnetic material at a lot of craft supply stores and then cut them with scissors to the size and shape you need for any vent. Not that expensive, but they do usually come in pretty bright colours. I've been able to purchase plain white though and it works really well. A LOT less $$$ than the purpose built covers. Exact same stuff as in Elk's post. Looks like they've bought the stuff and repackaged it and are calling it a vent cover. (and I'm sure boosting the price)
    Willhound
  6. BrotherBart He Who Moderates
    Northern Virginia
    If you want free ones stop by any of the shops that make magnetic signs like you see stuck to cars. They screw up all the time and have to throw the material away.
    Of course you might have a vent cover that says "First Baptist Charch" or something like that.
  7. Corie New Member
    Halifax, VA
    hahaha, that's actually I really good idea though- Never thought of checking the sign shops... hmmmmm
  8. fespo Feeling the Heat
    South West burbs of Chicago
    Don't cover the Vents. I run the fan on my furance to move the air around the house better. It evens the house temp out. No hot spots See Ya
  9. Chuck Pearson Member
    Adrian, MI
    You don't want to cover all the vents, just the vents in the rooms that are closed off for the winter. That way you can circulate the air but not waste it where it isn't needed.
  10. vgrund New Member
    Amherst, NH
    If you intent to use the air handler, do not cover more than 20% of your vents in any particular zone you plan to use. Doing so may overload the air handler.
  11. Verynycegirl New Member
    Massachusetts
    Ok....without sounding totally dumb....what are the air handlers?????????????????
    Tracy
  12. vgrund New Member
    Amherst, NH
    They are the big fans that push air through HVAC ducts.
Thread Status:
