    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. rmac New Member
    central NJ
    I am installing an Englander 25 with a Dura vent flue kit. On the outside of the house, do I cut the siding around the square thimble, or do I screw the thimble over the vinyl siding and seal with silicone? Thanks for your help.
    #1
    Helpful Sponsor Ads!
  2. Shane Minister of Fire
    Casper Wyoming
    Either or so long as the clearance is maintained.
  3. STOVEGUY11 Feeling the Heat
    SOUTHERN CT
    They should offer a vinyl stand-off kit. We got lucky here, we were having the vinyl siding done on the building. So we cut our holes and sealed everything up. Then the guys just went around the thimbles and cleaned them up real nice.
  4. Bxpellet Feeling the Heat
    Bronx, NY
    I put mine outside the siding, and placed under the lip, and put silicone all around and screwed it to the wall, Just maintain your clearance or better.
  5. IIFAST4U New Member
    Western, RI
    Stupid question? How big does the hole have to be around the pipe. if I use a 3" vent pipe and cut the hole in the wall how big does the hole have to be?
    Thanks shawn
  6. Bxpellet Feeling the Heat
    Bronx, NY
    If you look at your thimble it will tell you what clerance is required, mine was a 3" vent pipe with the thimble it was a min of a 7/12" hole I made mine about 9".
    the flanges on the thimble covers everthing.
Thread Status:
