Vent pipe tied into wood stove Chimney
AlaskaCub Posted By AlaskaCub, Jul 30, 2008 at 1:57 AM
Thread Status:
  1. AlaskaCub
    AlaskaCub
    New Member 2.
    NULL
    Apr 4, 2008
    70
    0
    Loc:
    Interior Alaska
    I am just double checking before I order my vent pipe, my plan is to run the vent pipe into my existing wood stove 6" Metalbestos pipe via a 3" Selkirk adapter. Is there anything that I need to know before doing this. My wood stove chimney system is a up then out and then up again system. I am assumng that since this is a forced venting sytem that it shouldn't be a problem. Any important insights are welcomed.
  2. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,101
    Loc:
    madison hgts. va
    what unit are you installing , is it rated for such an install? i have one of our stoves direct connected to a 6 inch round 15 ft chimney and have had no issues at all with it. but then its an interior , masonry with 6" liner, insulated. i would think you wouldnt have issues as long as you were getting a solid draw when operating a woodstove through it. make sure the manufacturer says you can first and then you should be ok.
  3. AlaskaCub
    AlaskaCub
    New Member 2.
    NULL
    Apr 4, 2008
    70
    0
    Loc:
    Interior Alaska
    Its a P68, there were no draft issues with the wood stove that was in there last winter and the pipe is less than a year old. How does one find out if a stove is rated for a certain install?Here are a few pics of what the vent pipe is going into
    http://img.photobucket.com/albums/v228/DallSheep4me/002-11.jpg
    http://img.photobucket.com/albums/v228/DallSheep4me/003-8.jpg
    http://img.photobucket.com/albums/v228/DallSheep4me/005-4.jpg
  4. jtp10181
    jtp10181
    Minister of Fire 2.
    NULL
    Feb 26, 2007
    3,729
    3
    Loc:
    Madison, WI
    It would say in the install manual if that type of install is allowed. I think the Harman units are OK to do that but check your manual. Also you might want to get that soffit back on before you have animals living in your attic.
Thread Status:
