Q&A Venting problem
QandA
Staff member
Nov 27, 2012
0
Question:
I have an up and down fire places(one on main level and one on lower level) same chimney with separate flu's. Last year I put caps(three separate caps) on them to keep out debris but now I notice the upstairs is drafting to the basement fireplace the basement doesn't draft at all(I don't know if it ever did)also my furnace and hot water tank are vented through same chimney but also have a separate flu. Help!
Answer:
The caps are probably not helping any since the gases must exit the caps through the sides...and this bring the smoke next to another flue where it can be sucked down by a downdraft (usually when the other flues are not in use)
Solution is to maybe raise the center flue by a foot or so, and then the three chimney won't terminate right next to each other.
