Venting question..
RAKFROMNC
15
NC
USSC American Harvest 6041-I. This unit will be installed in a pre-fab metal firebox; with an existing 8" chimney. My question is: can you come off the unit with the 3" x 60" flex vent, past the damper and terminate inside the existing chimney ? Traditional wood inserts are done this way and wondering about pellets...
Thanks and Merry Christmas to all....
You really should either seal the chimney off so no back drafting can occur, or run the flex to the terminus at the top of the chimney and cap it so no water and such can enter the pipe.
The vent needs to be sealed to the exhaust housing on the stove with High temp silicone so no smoke or other flue gases can enter the room air intake system.
Hope this helps.
I am sure others will chime in here soon.
Snowy
Yes, I will be sealing off around the damper w/ hi temp insulation. There is already a cap and screen on the termination.
You can get the installation manual and that should lay out all of the acceptable vent installation options.
Manual "suggests" running new vent up and out, basically using my 8" chimney as a chase. My home was built 3 years ago and and have only burned a handful of wood fires in my fireplace, and not really thrilled about modifying my chimney termination. What is the exhaust temp difference btwn wood insert v/s pellet insert ?
The pellet stove exhaust will be less than 475 degrees, that is the point that the exhaust blower will stop and kill the stove. Most pellet stove installation manuals only call for 500 degree silicone sealant.
I have no idea about a wood insert.
There are two issues with using a chimney after a short length of pellet vent, one is the possibility of water entering the venting, and the other is that the cold air in the chimney will cause draft and byproduct condensation problems.
I can share my experience with you on this type of venting. My Quad Castile insert was installed in my fireplace and I installed a 1/8 inch thick aluminum block off plate to seal the damper area, it had a hole cut in it for the 3 inch flex pipe, and we packed the damper area with fiberglas insulation then caulked the edges to seal it tight. The installer ran the flex vent up into the chimeny about 6 feet.
This seemed to work ok, my insert ran ok, but I did notice that start ups were a little rough sometimes, in the real cold weather, the insert would often give a hefty " thump" after struggling to ignite with a lot of smoke in the firebox, and the draft didnt seem to be as good as I thought it should be because my flame never really danced around or was a whiteish color as I had seen in the showroom at the dealers. Occasionally when it was very cold I would also get a whiff of smoke in the room on startups, but I could never find a leak anywhere behind the insert, there was only 2 joints and they were tightly sealed with silicone.
After that season, I was talking with the dealer and I mentioned these issues to him, and he suggested that we install the vent pipe all the way up to the top of the chimney instead of just having the pipe in there part way. He said that often times when the chimney is very cold that cold air is so heavy it wants to drop down, and the combustion blower has to work a lot harder to overcome the density of this cold air and push its way up and out. Once the fire is going for a while the air in the chimney is warm and of course hot air rises and it flows better. So, we removed the short pipe, and put in one long one about 17 foot and terminated the top of the chimney with a stainless sheet bent all around and sealed tight with silicone, and a rain bonnet was put on the top. Prior to this all I had on top my chimney was the galvanized metal bonnet with screen to keep birds out of the fireplace. So now I have a tight seal at the top, and one long vent all the way down to the insert, and the damper area is sealed tight. No more large volume of dense cold air trying to drop down. The volume of the 3 inch flex is a lot less than the old 8 inch liner.
The difference was amazing. I have a much faster start up with almost no smoking or very little, and the flame is much more active, it swirls around the firepot and dances about nicely as it should, no lazy flame at all now, and there is never any odor at all when it ignites.
I suppose I could have left the short pipe in there as it did work, and once the chimney was hot inside the draft did improve but this new vent setup is so much better.
My manual shows several choices of venting, and using a short section of flex pipe into an existing fireplace chimney is one of those but, I dont think its that great, and I do know for a fact that going all the way up with the flex pipe worked a whole lot better.
Hope this helps you in your decision, its a little more money for the longer vent but its well worth the performance in the long run.
I just installed my insert into a pre-fabed sheet metal fire place. I went back and forth about what to do with the venting/OAK. I ended up just running the flex pipe to the top and terminating there with a cap I bought online. I think it ended up being 13' of 3" flex. I ordered the OAK, but I haven't got it yet. My plan is to do the damper block off and use the existing 8.5" liner as my intake. The stove works fine as is now, but would still like to make this additional mod
Thanks alot guys, all the info and suggestions are helpful as I am a greenhorn to pellet ownership....glad to be giving the heatpump a much needed break soon....
Another quick question : Has anybody had any issues with Santa not being able to come down their chimney due to an insert ????? 'Cause I hope to be on the good list this year...hope to !!
