Looking for some ingight here. I have a 60x60x18' man cave under construction and am going to partition off a 13x13x8' tall room for an EKO 40. I'll put in a 7' wide OH door to the inside of the shed so I can shove dry wood in there in empty totes w/ the skid steer. OH and man door to inside of shed are to keep smoke and dust contained in boiler room.
I'd like to power vent the room somehow so smoke and dust doesn't end up in the main shop when I refill and clean the boiler. I was thinking of a 16" or so fan ( maybe 2000+ cfm ) near the ceiling with gravity shutters thru the exterior sidewall, but the thought of that uninsulated aluminum shutter clanking away every time the wind is blowing isn't the best. Got them on a number of barn fans and they drive you nuts. I do have an exterior window I plan to open so the room doesn't go too negative while the fan runs.
With the cavern of an attic that I have - 120' of propper vents and ridge vent - do you think I could get away with simply ducting the air up into the attic and letting it dissipate up there? The attic volume is 10X the volume of my boiler room, and I hope the amount of smoke is modest. There may be some moisture effects or something I'm not thinking of now though.
How is everyone tackling this - ideas appreciated......
