Hello,
Just bought a used Quadrafire 1200. I am going to vent it through the wall and then up above the roof. Maybe 10' vertical. My question is this...I have access to about 20' of 41/2" stainless flex pipe and about the same length of 3" stainless flex pipe. I also have a bunch of durablanket insulation that is used to insulate kiln cars at a brick plant. Would it be too crazy to run the 3" flex inside the 41/2" flex using the durablanket as insulation between the pipes? Actually wrap the 3" pipe with durablanket and then run it inside the larger pipe. Or is this just too off the wall? Would it keep everything cool enough so I do not burn down the whole town? Would it draft OK being flex pipe? Kinda wondering what you all think. Been checking out this site for a bit, but did not see anything on this subject. I thought I would ask.
Thank you!
Thank you!
