    Hearthstone Soapstone and Cast-Iron stoves( Wood, Gas or Pellet Stoves and Inserts)
    Caluwe - Passion for Fire and Water ( Pellet and Wood Hydronic and Space Heating)
For Sale Vermont Castings Defiant Encore Model 0028
Post in 'Articles for Sale/ Wanted, etc.' started by CTPipeDream, Oct 6, 2013.
  1. CTPipeDream
    CTPipeDream New Member
    Aug 14, 2013
    12
    Loc:
    Andover, CT
    I am selling a professionally rebuilt Vermont Casting Defiant Encore model 0028 wood stove. This 0028 model stove was one of the first produced in the long history of Vermont Castings Encores and has been completely refurbished to showroom like conditon. You won't find a better stove then these Vermont Castings encores they are the gold standard in wood stove engineering and technology. This is a catalytic stove and burns with an efficiency rating over 70%. They are truly a great stove, I know I burn one to heat my home, so come take a look for yourself. The sale will include an owners manual and oval to round pipe adapter (required for installation). I also have some accesories like warming shelves and firescreens. Winter is coming fast so get ready now. Feel free to contact me with any questions you might have or if you would like more pics. I also have over 15 years in the hearth industry so if you have other stove questions feel free to ask. I also do repairs and can order any vermont castings parts you might need. Call Tony @ 860-965-7100
    Range of heat output .................8,700-41,700 Btu's/Hr*
    Maximum heat output ........................ 47,000 Btu's/Hr**
    EPA emissions ratings, g/h, catalytic .......................1.6*
    Area heated*** ............... Up to 1900 sq. ft. (175 sq. m.)
    Fuel size/type ...................... 18-20" (450-500 mm) logs
    Fuel capacity ...........................................40 lbs. (18kg)
    Loading .......................................................Front or top
    Chimney connector:
    for 8" flue collar ....................... 8" (203 mm) diameter
    for 6" flue collar ....................... 6" (152 mm) diameter
    Chimney flue size:
    for 8" flue collar .......................8" (203 mm) minimum
    for 6" flue collar .......................6" (152 mm) minimum
    Flue exit position ....................... Reversible, top or rear
    Primary air ...Manually set, thermostatically maintained
    Secondary air .........................................Self-regulating
    Ash handling system .....................Removable ash pan
    Glass panel ......................... High-temperature ceramic
    Weight .................................................350 lbs. (159kg)
    Width (leg-to-leg) ..................................... 27" (685 mm)
    Depth (leg-to-leg) .................................... 15" (380 mm)
    Height to top of flue collar, (6" or 8")
    Top exit .............................................. 25¹⁄₄" (640 mm)
    Rear exit ............................................ 26¹⁄₂" (675 mm)
    Helpful Sponsor Ads!
