Vigilant, Coal to Wood ?'s
bond893 Posted By bond893, Jan 4, 2014 at 3:54 PM
Thread Status:
  1. bond893
    bond893
    New Member 2.
    NULL
    Jan 4, 2014
    2
    0
    Loc:
    Boston
    Hi Everyone,
    I recently moved and the is an older, 70's-80's i think, Vigilant in our finished basement. The previous owner burned coal and swore by it, but we have no interest and would love to just burn wood. I know there was a conversion kit which I'm guessing is no longer available and they have you remove all the grates etc.
    After reading everything I can here, which is a lot, I went ahead and just fired it up with some logs with the grates still installed and seem to being going ok. I understand the firebox isn't as big and the wood will probably burn faster without sitting in a bed of ash, but are there any real problems with operating like this?
    I have had no problems keeping the griddle at 600-700 f and have had had it higher, 900 which scared me a bit, but its doing a great job heating.
    Any suggestions/advice? Should I remove the grates? Don't have the cash to replace so I'd love to make the best of it.
    I appreciate any and all help, thanks.
  2. webbie
    webbie
    Seasoned Moderator 2.
    NULL
    Staff Member
    Nov 17, 2005
    12,185
    1,087
    Loc:
    Western Mass.
    Not a big problem burning like that, but removal of the grates will give you a vastly bigger firebox. If you can find a set of the coal grate instructions, that may help to see if you have to fudge anything once you remove them.....to put it back to near stock.
  3. defiant3
    defiant3
    Minister of Fire 2.
    NULL
    Dec 23, 2010
    647
    45
    Loc:
    No. NH
    Does it have the 3 rocking type grates or many horizontally-opposed grates?
    webbie likes this.
  4. bond893
    bond893
    New Member 2.
    NULL
    Jan 4, 2014
    2
    0
    Loc:
    Boston
    It has the 3 rocking type grates.
    I have the manual, and understand how to disassemble it all. What then? From what I gather from here, an inch of sand in the bottom?
  5. webbie
    webbie
    NULL
    Staff Member
    Nov 17, 2005
    12,185
    1,087
    Loc:
    Western Mass.
    Yes, there are some manuals in the wiki, etc. for the old VC stoves......
    The 3 rockers is the old one.....so, yeah, remove it all.
  6. defiant3
    defiant3
    Minister of Fire 2.
    NULL
    Dec 23, 2010
    647
    45
    Loc:
    No. NH
    The only other thing is the primary air tube, which if memory serves was removed to install the coal kit. Woodmanspartsplus.com has them.
  7. dlj
    dlj
    Member 2.
    NULL
    Jan 10, 2014
    50
    5
    Loc:
    Monroe, NY
    It doesn't say anything about either removing or installing the primary air tube on this older model stove in my manual. You do want the left and right inserts and the ash fettle however to change the stove back to wood from coal. You can easily run the stove with the coal set-up, you just won't have the same amount of space to put in wood so your burn times will be shorter. You should be able to control the fire though without much problem even with the coal grates and sides in place. You'll need smaller wood pieces. They do work better for wood set-up for wood. Personally, I'd burn coal in it as it's already set-up for it. but that's up to you...
    dj
  8. defiant3
    defiant3
    Minister of Fire 2.
    NULL
    Dec 23, 2010
    647
    45
    Loc:
    No. NH
    Um, yeah so maybe you're thinking Resolute? Cause Vig.'s don't have left and right inserts? Or did I miss something?
  9. dlj
    dlj
    Member 2.
    NULL
    Jan 10, 2014
    50
    5
    Loc:
    Monroe, NY
    I have that vintage Resolute - the manual that came with it included the Resolute, Vigilant, and Defiant. In the manual it shows all the conversion parts for these stoves - as I don't have the larger two, I can't say for certain if in fact they have the parts mentioned. But I must ask - how would you put the three grate system into the larger two if they don't have the points of support for the coal grates and the space to run the shaker?
    dj
  10. defiant3
    defiant3
    Minister of Fire 2.
    NULL
    Dec 23, 2010
    647
    45
    Loc:
    No. NH
    Well the Defiant never had a coal kit available. The Vig. did, and all the supports ar3e built into the coal parts themselves. Hard to explain, but it works. Don't all Vig. fronts have a shaker hole? Earliest ones may not, in which case just drill it I guess. I've never come up against that!
Thread Status:
