    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. charly Minister of Fire
    Schoharie, NY
    #1
    Helpful Sponsor Ads!
    pen and fishingpol like this.
  2. Adios Pantalones Minister of Fire
    A half hour? I'm really surprised. Love it
  3. Jags Super Moderator
    Northern Illinois
    Totally cool concept. Like the old Coo coo clocks only different.
    charly likes this.
  4. begreen Super Moderator
    South Puget Sound, WA
    pen, charly and Jags like this.
  5. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    Very cool idea.
  6. charly Minister of Fire
    Schoharie, NY
    Exactly!!!
  7. Backwoods Savage Minister of Fire
    Michigan
    I can picture this going into many more things than just lighting. A fantastic idea and these folks are to be congratulated.
  8. charly Minister of Fire
    Schoharie, NY
    Seems like it's American made, wow that's a rarity:) . Imagine making something like that but stronger, and runs longer,,,a remote location battery charger, etc.
  9. FanMan Member
    CT stix
    Hmmm. Cool idea, but some perspective (do the math): A typical modern AA rechargeable battery is 2500 mAH, or 2.5 amp hours. At 1.5V, that's 3.75 watt-hours of energy. With a 20 pound weight dropping 3 feet that's 60 lb-ft of energy, which computes to 0.023 watt-hours, which means the single AA battery has 163 times the energy that one lift of the GravityLight's weight can produce.
    Conversely, to use it as a battery charger you would need to lift it 163 times to charge that single penlight battery, which would take nearly 3 1/2 days.
    Now, how bright can it be? A 20 lb weight falling 3 feet in 30 minutes is a power output of 2 lb-ft/minute, which works out to 0.0045 watts, An LED light which they're using, is very roughly 10X as efficient as an incandescent bulb, so you have the same light output as a 0.045W bulb. By contrast, a single candle produces about the same light output as a 1W incandescent bulb. So, the candle (which is not as bright as the kerosene lanterns they're proposing to replace) is roughly 20X brighter than the light the GravityLight can produce.
    Now maybe they're dropping it 6 ft rather than 3 ft which doubles the output, but offset that by the fact that the generator is likely to be at best 50% efficient, you're back to the above numbers.
    Add to that the fact that I've never heard of a cheap generator flashlight that lasted very long before breaking.
    Neat, idea, but unless I've slipped a few decimal points somewhere, not practical.
  10. charly Minister of Fire
    Schoharie, NY
    And that settles that;sick
