    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. outcast New Member
    i was at menards looking at stoves. they had tubes with holes on them on the ceiling of the stove. what do they do ?
    #1
    Helpful Sponsor Ads!
  2. Augie Member
    North Of Canada
    Check this thread here
  3. remkel Minister of Fire
    Southwest NH
    A simple answer- those are the secondary combustion air inlets.
  4. HotCoals Minister of Fire
    Rochester,Ny.
    If the stove gets to hot they spray water!
    Just joking..others beat me to the answer!
  5. remkel Minister of Fire
    Southwest NH
    I converted mine to a halon system, however I am finding it difficult to recharge the system :)
    PapaDave likes this.
  6. DianeB Feeling the Heat
    I am saving this link for my husband to read. I understand it, but he does not and goes from raging fire down to almost putting it out. He need to understand the concept of slowly damping down
  7. remkel Minister of Fire
    Southwest NH
    A little elaboration....these inject heated air into the gases to burn off more of the smoke/gases. This is what makes the stoves burn more efficiently.
  8. HotCoals Minister of Fire
    Rochester,Ny.
    Wonder what would happen if we ran nitrous oxide into those tubes?
    Just joking again!
  9. outcast New Member
    ah, i see. they are for propane flue injection :D
    PA Fire Bug likes this.
  10. HotCoals Minister of Fire
    Rochester,Ny.
    Sorta like a barbeque grill!
  11. Sprinter Minister of Fire
    Western Washington
    That's right. What makes EPA approved stoves so efficient over older ones is that they are designed to burn a lot of the combustion products that otherwise would go up the chimney. Smoke, some gasses, etc. One way to do that is to put those tubes with holes at the top. They are supplied with air and get so hot that they burn those products. That's called secondary burning. Secondary burning is quite visible and adds to the light show. My wife calls them the afterburners.
    Another way to do it with a catalytic burner.
    That's the short version. Much more to learn about stoves if you are interested and this is the place to do it. Welcome to the forum.
  12. outcast New Member
    thanx for the video.
  13. outcast New Member
    yeah, i have a lot to learn. and you folks are nice enough to help me.
    were does the secondary air come from ?
  14. HotCoals Minister of Fire
    Rochester,Ny.
    There are separate inlets to do that job that are non adjustable.
    Though some have found ways around that.
  15. remkel Minister of Fire
    Southwest NH
    Now THAT would be a runaway stove!
  16. corey21 Minister of Fire
    Soutwest VA
    They are for picking off unburnt gasses that the wood fire did not burn.
  17. outcast New Member
    thanx guys :)
  18. WellSeasoned Minister of Fire
    Eastern Pa
    Oh man, now that was funny! Holy S
