What is 10.5 Vdc
THE ROOSTER Posted By THE ROOSTER, Jan 15, 2012 at 10:28 PM
  1. THE ROOSTER
    THE ROOSTER
    Feeling the Heat 2.
    NULL
    Feb 22, 2009
    353
    6
    Loc:
    Home of Wild Turkey 101 & Lake Cumberland
    I take it that it is 10.5 volts. That is what the owners manual says is the cut out for the Harmon 512H on a 90 A/hr battery, now I am not using one I am using golf cart batteries.
  2. Former Farmer
    Former Farmer
    Feeling the Heat 2.
    NULL
    Apr 12, 2008
    387
    66
    Loc:
    NE Wisconsin
    Just as Smoke Show said - 10.5 volts dc. Typically the battery would be 12 volts dc. When the battery gets drained down to 10.5 vdc, the stove would quit running.
    To give you an idea, your car battery is 12vdc. When your car is running, your voltage will increase to 13.5 to 14.5 volts dc because of the alternator generating electricity. If you have your headlights on while your car is running, the lights are quite bright. If you turn off your engine, leaving your lights on, you will notice that the lights dim some. The longer you leave them on, the lower the voltage from the battery gets and the dimmer the lights get.
    So as the voltage from the battery on the stove drops, the fans and auger would also run slower. The 10.5 volts is where the manufacturer has decided that the stove is not running effectively and that the voltage in the battery wouldn't last much longer.
  3. 76brian
    76brian
    Feeling the Heat 2.
    NULL
    Nov 5, 2011
    394
    3
    Loc:
    Ottawa, Canada
    Actually, 10.5 volts is where the manufacturer has decided that the inverter will shut off. Because if you discharge a lead acid battery lower than 10.5 volts, you just toasted the battery. Buy a new one.
  4. THE ROOSTER
    THE ROOSTER
    Feeling the Heat 2.
    NULL
    Feb 22, 2009
    353
    6
    Loc:
    Thanks for all the input, I now am only using 4 six volt batteries that are left overs from my golf cart. I had one of those go bad, so I got six new ones for the golf cart and kept four of the old ones for the pellet stove. I have gone 5 hours so far on batteries that are 8 years old.
    Thanks again for your input
