what size boiler do I need?
Curt-Lennox- Winslow Posted By Curt-Lennox- Winslow, Oct 13, 2013 at 10:11 AM
Thread Status:
  1. Curt-Lennox- Winslow
    New Member 2.
    NULL
    Apr 7, 2013
    9
    0
    Loc:
    Southern NH
    I have a 2700 sq. colinial with an unfinished/unheated basement. I currently use oil for my hot water and baseboard heating (forced hot water). How do I determine what size pellet boiler to look at for heating my house and domestic hot water? Is that something to leave up to the pellet boiler salesman or is there another way to figure it out? I have a pellet stove on the 1st floor but it doesn't heat the whole house evenly.
    Curt
  2. PassionForFire&Water
    Minister of Fire 2.
    NULL
    Jan 14, 2011
    645
    123
    Loc:
    Billerica, MA
    To give you some first ball park number on heat loss, you can use these guidelines for "moderate" New England conditions:
    - old house not insulated or poorly insulated: SF of house x 37 BTU/sf
    - house in 2x4 stick construction fairly well insulated: SF of house x 30 BTU/sf
    - house in 2x6 stick construction very well insulated and tight: SF of house x 25 BTU/sf
    - house in 2x6 stick construction super insulated and very tight: SF of house x 15 BTU/sf
    - Passive House: SF of house x 8 BTU/sf
    Example:
    a 2x6 stick build house in 2012 of 2,500 SF should have a max heat loss of 2,500 x 25 = 62,500 BTU/hr
    The same square footage for an old house would result in 2,500SF x 37 = 92,500 BTU/hr
    The above guidelines include for DHW for 2 adults and 2 kids.
    These guidelines are up for lots of discussions and other trade professionals will have their say on them, but it gives you a ballpark.
    If you apply them you will not end up with a boiler that is way over-sized.
    stayfitz and Bster13 like this.
  3. PassionForFire&Water
    Minister of Fire 2.
    NULL
    Jan 14, 2011
    645
    123
    Loc:
    Billerica, MA
    Bster13 likes this.
  4. R Mannino
    R Mannino
    Member 2.
    NULL
    Sep 4, 2008
    89
    5
    Loc:
    Long Island, N.Y.
    Smaller is better with boilers unless you have storage.
    hobbyheater likes this.
  5. heaterman
    heaterman
    Minister of Fire 2.
    NULL
    Oct 16, 2007
    3,355
    622
    Loc:
    Falmouth, Michigan
    Or a boiler that can modulate as some pellet boilers are able to do. That feature allows a fair amount of margin for error.
  6. Curt-Lennox- Winslow
    New Member 2.
    NULL
    Apr 7, 2013
    9
    0
    Loc:
    Southern NH
    heaterman, what do you mean when you say a boiler that can modulate. I am looking at a windhager biowin 21.
  7. maple1
    maple1
    Minister of Fire 2.
    NULL
    Sep 15, 2011
    7,082
    1,220
    Loc:
    Nova Scotia
    Speed up & slow down. By themselves.
  8. PassionForFire&Water
    Minister of Fire 2.
    NULL
    Jan 14, 2011
    645
    123
    Loc:
    Billerica, MA
    Modulating in case of the BioWIN = heat output BioWIN matches the heat loss of the house (heat demand)
    From max heat output to 30% of max.
  9. heaterman
    heaterman
    Minister of Fire 2.
    NULL
    Oct 16, 2007
    3,355
    622
    Loc:
    Falmouth, Michigan
    The 21kw unit you are looking at will go from a maximum firing rate of about 72,000 btu down to about 23,000 btu.plus run anywhere in between in as little as 1% increments.
    This enable the boiler to match what is going on in the home whether you have one heating zone calling or all of them. (provided you have a multi zone system of course)
  10. Dana B
    Dana B
    Feeling the Heat 2.
    NULL
    Mar 17, 2013
    434
    93
    Loc:
    So. New Hampshire
    Curt:
    As Marc pointed out earlier the BTUs needed for your home are largely determined by how well insulated it is. I recently purchased a Biowin pellet boiler but I'm also undertaking insulation projects in both my basement and attic.
    Like me I'm assuming you're considering the pellet boiler as a way to save money on energy costs. If you're seriously considering a pellet boiler it would behoove you to take a holistic approach to the energy efficiency of your home to see if there are ways that you can improve upon your home's insulation and air flow. There is a wealth of information at your fingertips on the internet about insulating your home properly.
  11. Nofossil
    Nofossil
    Moderator Emeritus 2.
    NULL
    Oct 4, 2007
    3,603
    68
    Loc:
    Addison County, Vermont
    Do you know what oil consumption was for the last heating season? That can help dial in your heat usage. Rule of thumb: Peak heat load = twice average heat load.
  12. Curt-Lennox- Winslow
    New Member 2.
    NULL
    Apr 7, 2013
    9
    0
    Loc:
    Southern NH
    Nofossil, my oil consumption for last winter was about 300 gal. for heating hot water, as I heat with a lennox pellet stove. My last year on oil only was about 800 gal.
    Curt
  13. Nofossil
    Nofossil
    NULL
    Oct 4, 2007
    3,603
    68
    Loc:
    25 gallons a month for hot water is a bit higher than average, I think.
    A gallon of oil in a typical boiler provides around 100,000 to 120,000 BTU of usable heat. Back of the envelope calculation:
    Assume a 4 month heating season.
    25 gallons a month for hot water, and 125 gallons a month for heat (your extra 500 gallons from your 800 gallon year divided by 4 month heating season).
    That's about 3800 btu/hr average for hot water and 19,000 btu/hr average for heat. Your peak heat demand would be about twice as high, or 38,000 btu/hr.
    That means that a 45,000 btu/hr pellet boiler would be completely maxed out on a really cold day. You'd want some headroom, but 60,000 btu/hr seems like it would be in the right range - maybe a bit higher to allow for quicker recovery.
    Of course, your mileage may vary. I'd try calculating it a couple of different ways.
Thread Status:
