What size of connections for storage
taxidermist
1,057
Fowlerville MI
I have to weld in fittings for my storage tank. What size for supply and return and also how many should I put in the tank? The tank is a 530 gal square
Thank you,
Rob
Thank you,
Rob
Pipe, fitting and tube sizes are always based on flow. What GPM will you need to handle?
If I was going to the trouble of having fittings welded to a tank, I would probably go with 1 1/2 inch, and then use off-the-shelf reducers to get it down to whatever size you actually end up needing to plumb it.
Much easier to go to Home Depot or the plumbing supply store and change the size down to what you need instead of having to live with something that was welded to small.
That said, my propane tank came with 1.25 inch fittings, and that is what I plan on using because a) I think it will work, and b) I am too cheap to hire someone to weld anything else on.
heaterman said:
Thank you,
Rob
EKO 60 530 gal now with 500 gal propane tank in the future for a total of 1030 gal I will have 125' between boiler and tank.
Rob
Good advice from MrEd. Just weld in some 1 1/2 couplings. You can always bush them down or plug them.
