What's causing this?
kversch
153
New York
What's causing my stove to do this? Is this back puffing? Or a down draft?
Can't tell, no pic or low res pic if it's your avatar. Tell us more
Trying to get a video to upload but having trouble
Can't figure out how to upload a video can someone help me out?
Well until I can get the video to load. The best way I can describe what was going on would be I had good secondaries on a small load on a fresh start up from a cold stove. You would kinda hear a faint Iike poof and it looked as if the secondary's were blown down (they were running like the gas stove jet) and almost out then quickly reignigt. It also seemed like when they were going and this would happen it almost looked as if the flames were all getting sucked up the chimney.
I'm sure this is confusing sounding but it's the best way I can describe it.
Photo bucket or similar would work too.
Had you cut the air down? It sounds like you ran out of air, the fire went out, then reignited once the fresh air moved in.
You didnt mention that smoke entered the house, so back puffing seems unlikely.
It's not that weird, actually. It's usually caused by an eratic or insufficient primary air flow. All the oxygen gets used up at once, then the firebox refills and POOF it happens again. By opening the primary draft control even slightly it should stop happening. Bet your wood is really dry. Like really dry.
