    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. senornick New Member
    I'm new to wood and my little Englander 17 doesn't burn thru the night and I burn manzanita.
    I was wondering what some of the long burns are on a single load.
    Exaggerations welcome.
    #1
    Helpful Sponsor Ads!
  2. HotCoals Minister of Fire
    Rochester,Ny.
    Almost 2 days once on a full load of black walnut.
    no joke..lol.
  3. jatoxico Minister of Fire
    Long Island NY
    That didn't take long ==c.
    jeff_t likes this.
  4. rdust Minister of Fire
    Michigan
    33 hours or so during the shoulder season.
  5. jdp1152 Minister of Fire
    Massachusetts
    5hrs. Very small firebox.
  6. HotCoals Minister of Fire
    Rochester,Ny.
    I must admit it was in the shoulder season..around 30f avg temp.
    Next room over started at 75f for a temp and ended up at 65f.
    But the new load did take off with some kindling from the coals!
    We were away.
  7. fox9988 Feeling the Heat
    NW Arkansas
    29 hours recently, maybe a cup full of coals left. It wasn't making any real heat, but I was able to reload without any kindling. I usually do 12 hour reloads.
  8. Beetle-Kill Minister of Fire
    If you count coals as part of an active burn- Sept.-to-June, my longest burn, hands down.
    Cold stove-to-hot-to-cold stove again. Again, Sept.-to-June.
    realistically- 12-30 hours, dependant on weather.
    jeff_t and Mitch Newton like this.
  9. katwillny Minister of Fire
    Dutchess County NY
    On my NC30 I can get a good 8 hours on Locust, Oak burn, 6 on other woods.
  10. ailanthus Member
    Shen Valley, VA
    Was pretty happy to get 13 hours on a load of BL - no heat at the end, just plenty of coals. That's probably the most I'll ever get w/ such a small box, though.
  11. corey21 Minister of Fire
    Soutwest VA
    I put a load of oak in last night and got 8 hours.
    Edit. I could have went longer the ways coals looked this morning.
  12. Jack Straw Minister of Fire
    Schoharie County, N Y
    Longest burn? Last spring, went for about 3 weeks. I had hemorrhoids.
  13. jharkin Minister of Fire
    Holliston, MA USA
    Welcome Senor.... You will come to learn that threads like this become a blaze king showoff discussion ;)
    Longest I've been able to go and relight without a match is 14 hours or so. Longest usable heat is about 10 hours on a full load of oak.
  14. jeff_t Minister of Fire
    SE MI
    ;lol
    Yep, you need to exclude BK burners. I'll bite though, 48 hours, no kindling.
    It's mostly about the firebox on the average stove. That 17 is pretty tiny.
  15. Wood Duck Minister of Fire
    Central PA
    I have a stove that I think is pretty similar to the NC17. I can get 8 hours from reload to barely enough coals to relight without a match. The stove at the end is warm but not hot, so I am not getting 8 hours of good heat.
  16. num1hitter New Member
    Reading, PA
    I can relight with coals consistently with burn times of around 8 hours. 12-13 hours has been my best to get a relight with no matches. But useful heat typically dies out after 5 hours.
  17. Hass Combustion Analyzer
    Alabama, NY
    60-65 hours is normal with a load of ash when it's 20-30F
    I always burn on lowest after an initial charring, otherwise I get roasted out of the house.
    Usually it's only about 30-35 when I use hardwood 4x4s, they're damp and I can't cram very many in while leaving air gaps.
  18. Todd Minister of Fire
    Lake Wissota
    Woodstock Keystone 1.4 cu ft fire box- 14 hours with enough coals to reload fresh splits without kindling.
    Blaze King Princess 2.8 cu ft fire box- 33 hours and could probably squeak out 40 if I tried but consistantly 24 hour burns are more practical.
  19. ohlongarm Minister of Fire
    Northeastern Ohio
    I can get easily 20 hrs of usable heat loaded for bear with oak,and black locust,temps in teens.But I'm not into burning marathons the stove now is only required to maintain a constant temp for 12 to 15 hrs,of usable heat.If you want to talk burn times in warm and fuzzy land I can re-start any load without kindling 24 to 30 hrs later,but felt there was no need to go longer than that.The stove just plain works,I quit my job as a stove babysitter in March 2011 when I went with a BKK.
  20. senornick New Member
    WHAAAT? 5...8...12...14..20 hrs? 48?!
    Maybe I'll get a Blaze King.
    I'll start with a new ash can.
  21. BrowningBAR Minister of Fire
    Doylestown, PA
    Vigilant 2.8-ish cu ft firebox: 8 hours was the longest. Usually meant I smoked the hell out of the burn. Usually 5-6 hours of heat.
    Intrepid: 8 hours of heat was the longest. No idea how I managed that. Usually 3-4 hours of heat.
    Hearthstone 2.3 cu ft firebox: 8 hours of heat was the longest. Usually 5-6 hours.
    Encore 2.3 cu ft firebox: 12 hours of heat has been the longest. Usually 6-10 hours.
    Defiant 3.2 cu ft firebox: 16 hours of heat was the longest. Usually 9-10 hours of heat.
    30NC 3.5 cu ft firebox: 11-12 hours of heat has been the longest. Usually 8-10 hours of heat.
  22. Waulie Minister of Fire
    Nothern Lower Michigan
    Longest restart from coals is 20 hours, but I'm sure I could go much longer. Sitting around waiting to load until just before the last coals die out just isn't much fun to me.
    Longest burn still with decent heat was about 17.5 hours.
  23. katwillny Minister of Fire
    Dutchess County NY
    Sounds like Blaze King is the way to go, but i guess the question is, what are prices on these beasts?
  24. Kevin Dolan New Member
    SW Ontario
    I also have a castine and I think the longest burn I have had is about ten hours but really only with enough coals,to restart. For me that works fine as that is well past overnight for me. Although the box is relatively small compared to the big dogs on the forum, some of them anyway, I can still pack in some nice large pieces of hardwood.
    Kevin
    ailanthus likes this.
  25. Highbeam Minister of Fire
    West half of the nation costs are not as high as hearthstones, but much higher than englanders, say 3000$. In NY, you guys have price gouging occuring with the BKs so the dealer makes a big difference, like thousands of dollars difference.
    For the record, Hearthstone heritage I could go 10 hours and on the princess in my sig an easy 30 hours. All with low btu fuel and measured from startup until restart from coals just as the manufacturers do.
