I have been raised that pine=creasote. How long do you guys season pine and the such. Just cut two big white pines for a friend and he wanted the wood removed. Got at least a cord and a half Ill guess. Would you season split or not split?
Season split. Debarking some or all will help as well.
A year should do you.
If you want to be sure, split it smaller than you normally would. Also, I have found that a 10-12 inch log LENGTH seasons much faster than a 16-18 inch log.
My experience has been at least a year.
We have mostly white pine and oak species here (some maple in the lowlands) and they both need as much drying time and effort as possible for maximum heat/clean burn.
I burn pine - jack, white and red - almost exclusively in my gasification boiler. Always dried. Pine tends to burn a little hotter due to the sap/resin in the wood. So a little more air control might be necessary. Also, give some extra attention to the chimney just to make sure you're not getting creosote. You shouldn't if the stack temp stays up and you get a pretty complete burn in the stove. Don't have "cool" fires and watch the low burns especially.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
