Whitfield Advantage WP2
demus72
4
Northwestern US
Hello,
I was given the above mentioned stove and when cleaning found what I believe to be a limit switch and wiring burned and just dangling. It is the one that is on the combustion air pipe at the bottom and on the right side as you look at the rear of the stove. Where can I purchase a replacement online? My local pellet stove store hasn't been any help at all.
Thank you!
You can order one from Grainger or get it locally at an HVAC store. It sounds like the low limit switch that turns off the fans when the exhausts dips below 90 degrees. I believe it's a normally open 90 - 120.
If you are talking about the low limit switch mounted on the combustion blower housing or exhaust outlet it is 140 deg and the best to get is the ceramic type
you can get it here http://woodheatstoves.com/whitfield-pellet-stove-low-limit-switch-f140-ceramic-p-384.html and use coupon code hearthtools.com for a discount and priority handling.
if it is the swich mounted on the 2" AIR INLET TUBE this is a hi limit switch
http://woodheatstoves.com/snapswitch250-dg60t21-12127705-p-2903.html
use the same code for a discount
Is the stove up and running now?
