Why open the damper after putting in more wood?
DeanBrown3D Posted By DeanBrown3D, Oct 21, 2006 at 1:48 AM
Thread Status:
  1. DeanBrown3D
    DeanBrown3D
    New Member 2.
    NULL
    Oct 16, 2006
    193
    0
    Loc:
    Princeton, NJ
    I'm new to my VC catalyst fireplace, and I am wondering why my instructions say to leave the damper open for 15 minutes every time I add new wood (to a hot fire). My only guess is that if I left it shut,too much smoke would get the catalyst and overheat it, but I don't really know.
    Do you guys all do this or not?
    Thanks!
    Dean
  2. Todd
    Todd
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    9,229
    349
    Loc:
    Lake Wissota
    My manual says the same thing, but also state it is to drive off any moisture in the wood to prevent thermal shock to the cat. Not good for the cat. Also says smoke will poor out the loading door.
  3. DeanBrown3D
    DeanBrown3D
    New Member 2.
    NULL
    Oct 16, 2006
    193
    0
    Loc:
    Princeton, NJ
    I don't mean while the loading door is open, I mean after I have put wood in and closed the door, I'm supposed to leave the damper open for a while.
  4. elkimmeg
    elkimmeg
    Guest 2.
    NULL
    Dean the damper is the by pass to the cat all the smoke and moisture when starting a new log will clogg that cat up and render it useless. A cat does require more attention
    however inorder to get the new logs in proper buening situation the damper should be open in most stoves cat or non cat.
    What i do is open the cat 30 seconds first then add the wood this prevents smoke spillage into you room if you open the door dampered down
  5. Roospike
    Roospike
    New Member 2.
    NULL
    Nov 19, 2005
    2,859
    3
    Loc:
    Eastern Nebraska
    Right , Cat or non-cat stove when reloading new wood you need to keep the damper open ( full open , half open ) to char the new load of wood . Over all at what ever the secondary burners is doing you will get over all performance out of your stove , out of your wood and the control temps of the stove . Reloaded wood that has not been chard will lag down and become a turd and sometimes it will kill your fire and smother your coals and coaling wood.
  6. Roospike
    Roospike
    New Member 2.
    NULL
    Nov 19, 2005
    2,859
    3
    Loc:
    Eastern Nebraska
    Hahahaha .........
    I dont know if you help any newbes with that come back or made it worse. But at least an A for effort .
Thread Status:
