    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    I have installed my woodstove recently. I have found that It will effectively heat most of the house with a fan set on low blowing over the top of it from behind. I have found that the stovepipe temp drops dramatically when I use the fan this way. <p>
    Am I going to have more of a problem with creosote buildup with this setup? The stove pipe temp without the fan ran between 250 and 500 degrees. With the fan it runs 100-250 (usually 150-200). To reiterate my question: Will the lesser temperatures of the stovepipe cause increased condensation of creosote? and furthermore will it produce dangerous amounts?
    Answer:
    If the inside stack temperatures are really this much lower- and if your stove is an older model- it could lead to increased creosote or condensation. However- since your thermometer is probably a surface type- it may not be measuring your temperature accurately. You can purchase probe thermometers if you want a more accurate idea.
    #1
    Helpful Sponsor Ads!
Thread Status:
