Winslow PI40 - No lights - nothing
Brian Bo Posted By Brian Bo, Jun 11, 2013 at 6:57 PM
Thread Status:
  1. Brian Bo
    Brian Bo
    New Member 2.
    NULL
    May 25, 2013
    1
    0
    Loc:
    Massachusetts
    Hi,
    My Winslow PI40 does nothing after we had a lightning storm a few weeks ago. The manual says the control board is bad. I took the board to an electronic technician without a diagram and he checked a few things and said that it looked good but he was not sure. He said to look at the power supply / transformer.
    I have my meter set on 20 ACV and am registering .3 volts when I put on most pins including the black pin which seems very low.
    The cord comes in. Green goes to Ground. White goes to Bus terminal. Black to 10 pin connector.
    I am unable to download a .doc of the diagram but link below is .PDF
    Wiring diagram is on page 25 of this link
    http://matchless.info/~jmadden/downloads/174/Len%20Winslow-PI40(II&CO).pdf
    The control board is over $400 so I want to make sure before I call some one.
    Thanks
    Brian
  2. smwilliamson
    smwilliamson
    Minister of Fire 2.
    NULL
    Dec 28, 2009
    4,501
    782
    Loc:
    Southcoast, MA
    Did you inspect the fuses?
  3. smwilliamson
    smwilliamson
    Minister of Fire 2.
    NULL
    Dec 28, 2009
    4,501
    782
    Loc:
    Southcoast, MA
    Also check the power in on the cord, white and black. Check power to thermo switch. In and ground
  4. Don2222
    Don2222
    Minister of Fire 2.
    NULL
    Feb 1, 2010
    7,907
    474
    Loc:
    Salem NH
    Hi Brian
    Set your meter on 200 VAC scale and see if you have 120 vac where the black and white wires come into the stove.
    See my pc (private conversation)
  5. briansol
    briansol
    Minister of Fire 2.
    NULL
    Jan 18, 2009
    1,913
    293
    Loc:
    central ct
    First, did you try a new outlet? plug a lamp in and make sure its not the house?
    How about the surge protector/strip? Just checking :)
    how about the fuses? there's 2. are they good?
Thread Status:
