Wood add on furnace
Danscott138
1
Ontario
I currently have oil furnace with wood add on furnace. Oil tank is due for a change, I'm curious if this is possible? Air handler furnace with heat coil and ac coil fueled by a propane tankless hot water tank with 120v circ pump. Can I still use the wood add on furnace with shared duct work. Wood add on does not have blower fan.
yup, just put the add on up stream of the air handler. (blow through it)
