Wood Burning Stove Top Heat Powered Stove Fan
Gravedigger
31
Far Hill, MD
Will Blaze King Princess insert run a
Yeah but you will probably be disappointed in the performance.
The blades will turn, but the amount of resultant air movement is negligible.
My $.02 & I sold them for a while. Not that a lot of folks bought them...
Some folks get a kick out of them. Personally, I see them as more of an expensive novelty item than a useful component of a home heating system. YMMV Rick
I can tell you that one fan does not move much air across a stove, I would think that it would not do much with your insert. Is there a problem with your insert fan?
Does not do very much. I use it more for a visual indicator on when I need to reload and when stove is running hot.
I purchased one of these a few years ago and it worked awesome. Just have to make sure your stove top has room.
What Ozzy said. I bought one and I am very disappointed in its performance. And it was expensive too! Like Ozzy, I use it to tell me if the stove is running hot or cold.
