Wood burning too fast with the damper almost shut
ucanhackett Posted By ucanhackett, Mar 10, 2010 at 3:04 AM
Thread Status:
  1. ucanhackett
    ucanhackett
    New Member 2.
    NULL
    Mar 10, 2010
    1
    0
    Loc:
    Wester, NY USA
    What could be causing my wood to burn fast with damper almost shut? I have US Blaze stove and we put a manuel damper in the pipe when we first got it as the one in the stove let in too much air. The chimney was cleaned yesterday and now my wood is burining fast with the damper almost shut. Does anyone have any suggestions.
  2. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,890
    8,631
    Loc:
    South Puget Sound, WA
    Not sure what a US Blaze Stove is, but if it's drawing hard, close the flue damper all the way. It can't block the pipe completely. There are holes in the damper plate.
    What kind of flue is on the stove?
  3. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Welcome to the forum ucanhackett.
    Yes, with the flue damper closed that will restrict the air flow so the stove should not burn too fast. With you being a new wood burner I am wondering what you consider burning too fast? Is it just that the stove is throwing too much heat? Answer then is to put less wood in, especially this time of the year. Small fires and you can burn them hot but put too much wood in and then you are trying to slow the stove down. It doesn't work too well and you'll end up with even more problems. If the wood is marginal then by trying to smother the fire you will end up with some big time creosote problems....and you do not want that.
    New wood burners: check your chimney at least once per month.
  4. polaris
    polaris
    Feeling the Heat 2.
    NULL
    Jan 31, 2008
    419
    5
    Loc:
    KY.
    Is this a modern EPA rated stove? If it is not and isn't airtight then you might be able to overcome what benefit you are getting from closing down the damper through air comming in from the ungasketed joints in the stove. This is just pure speculation though without knowing what kind of stove you have.
    Joe
  5. thewoodlands
    thewoodlands
    Minister of Fire 2.
    NULL
    Aug 25, 2009
    10,825
    2,930
    Does it have a ash pan, if it does make sure it's shut.
    zap
  6. btuser
    btuser
    Minister of Fire 2.
    NULL
    Jan 15, 2009
    2,070
    249
    Loc:
    Principality of Pontinha
    Sounds like you've got a leak. When I've got a roaring fire and I shut the air off I can hear the flames sucking for air. There's only so much air my 15' chimney will pull. If you've got a long chimney that big draft can pull REALLY hard.
  7. Wood Heat Stoves
    Wood Heat Stoves
    Minister of Fire 2.
    NULL
    Jun 12, 2009
    1,905
    14
    Loc:
    Nevada City, California
    use smoke (insense stick) trace around door and glass gaskets, welds and the whole firebox to see where all the "extra" air is entering firebox
Thread Status:
