    Hearthstone Soapstone and Cast-Iron stoves( Wood, Gas or Pellet Stoves and Inserts)
For Sale Woodstock Fireview 205 refurbished wood stove
Post in 'Articles for Sale/ Wanted, etc.' started by pritch, May 1, 2014.
  1. pritch
    pritch New Member
    Nov 7, 2013
    2
    Loc:
    Bedford, IN
    Basically in refurbished condition as I just took apart, cleaned up, replaced the stone under the front door and back interior corners, used Woodstock cement to coat some of the interior scratches, replaced every gasket, mortared and reassembled with Woodstock cement. Metallic blue color to the cast iron pcs which IMHO contrasts nicely with the double-wall soapstone panels. A replacement stainless steel catalytic combustor has been used about 1 month. Comes with bottom and rear heat shields as well as the outside air intake adapter.
    Although currently installed on the rh side, because of the Fireview design the load door can be dismantled and located on either the right or left-hand side.. $1550 Contact phn#: 812-278-6436
    Helpful Sponsor Ads!
